Sponsored by: Real Truck
15-30mph vibration
Old Apr 2, 2011 | 05:14 PM
ford4x4s's Avatar
ford4x4s
15-30mph vibration
2002 f250 crewcab 8ft bed 4x4 7.3l. 83,000 miles, not worked hard...when im driving i'm getting a vibration through out the truck. not excessive in steering wheel. vibration starts around 15mph and fades around 30. the vibration is worse with more load on truck, either acceling up a hill, or load in bed or just acceling hard. no obviously bad u joints, carrier bearing looks good, tranny mount looks good, all weight still on wheels. also, i jacked up rear and ran it through gears. vibation very faint but there... if i held brake and hit gas while on th jack the vibration was a bit worse. also, i didnt see any weight fallen off drive shafts....on a side note, occasionaly when im driving as ,i believe, the truck is either shifting into od, or the tourque converter is doing whatever it does, there is a quick groan and slight vibration then goes away...also is more noticeable when towing. groan last only a second or two.anyways, they may be related, might not.....thanks for any suggestions.
Tugly
Jul 4, 2014 05:51 PM
jjoel
Jun 11, 2010 06:24 PM
ford4x4s
Dec 19, 2009 07:35 AM
t-roy
Aug 12, 2008 07:45 PM
x.l.r.8
Aerostar
Aug 7, 2005 09:47 PM
