Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
purchasing a F700 vin decode help please
Old Feb 10, 2020 | 10:39 AM
  #31
mrstang01's Avatar
mrstang01
Thank you sir!
Old Feb 10, 2020 | 10:52 AM
  #32
adventure-west's Avatar
adventure-west
Post a larger picture, I cannot read this puppy and it cannot be enlarged.
I know its a 16244 eaton rear end but the stamp they used for ratio is all messed up. It has a j2 trans code. It is a 5 speed with a granny gear.
Old Feb 10, 2020 | 11:25 AM
  #33
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
N70 = LN700 (gas).
B = 370 4V (6.1L).
V = Kentucky Truck Assembly Plant.
EC8352 = 1979.
220" Wheelbase.
C6: C = Pure White // 6 = Dark Cordovan Metallic.
N702 = N700 (gas), 23,000 lbs. GVWR
8B8: 8B = Black Heavy Duty Vinyl - Full Width Seat // 8 = Custom or Standard Cab without Butterfly Hood.
J2 = Clark model 282V 5 Speed Direct.
E2M:
E2 = Eaton model 16244 Two Speed Rear Axle // 6.17/8.58 // 17,500 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
23,000 lbs. Gross Vehicle Weight Rating.
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 5, 2020 | 11:56 AM
  #34
GorillaRodz's Avatar
GorillaRodz
1990 F700
Hi. I have a F700, vin 1FDNK72PXLVA15434. Axle code is 51M. 6.6 Brazilian with Allison auto. Can you decode any more info? Thanks
Old Apr 5, 2020 | 03:55 PM
  #35
NumberDummy
Cannot presently decode 1990 and later, contact Green Sales Co. for assistance (800-543-4959).
Old Aug 25, 2020 | 07:52 PM
  #36
john bogart's Avatar
john bogart
4th Gear
1FDNT74P6HVA63305
Old Aug 25, 2020 | 08:03 PM
  #37
85e150's Avatar
85e150
'87 F700.
https://www.vindecoderz.com/EN/check...NT74P6HVA63305
There is more info in the VIN, but the on-line decoders either don't go that deep or want you to pay.
This one is a little better and gives you the engine and GVWR, which with the year and model is about it for the VIN.
https://vincheck.info/check/vehicle-specification.php
Under CDL 26000 GVWR, 6.6L Brazilian 6 cylinder diesel.
There should be a lable with trans and axle codes on the door jamb or door face, driver side.
Old Jun 21, 2021 | 12:59 PM
  #38
Qndskmo69's Avatar
Qndskmo69
Can you decode 1983 c8000 1FDYD80U5DVA38627? Engine HP (10.4L Cat) and transmission if possible. Thanx
Old Jun 21, 2021 | 02:24 PM
  #39
85e150's Avatar
85e150
Welcome to FTE!
Well, this is a great way to welcome a new member, but I don't have a way to decode that VIN. And the decoders in post 37 above give you only the very basic info, if any at all.
Info on the Cat 3208 is available by simple search. You may be able to see model specifics on a plate or sticker on the engine, and you can tell if it's NA or turbo.
The transmission will have make and model info cast into the case or on a plate on the case.
Old Jun 22, 2021 | 11:08 AM
  #40
Qndskmo69's Avatar
Qndskmo69
VIN Decode
Dont beat yourself up about it, The ford dealer said it was a 10.4L Cat or 12 liter Detroit. I know its a 3208Cat but I havent seen it yet & dont know if its turbo or not. One decode said 175 min HP 250 max HP. Anyway I appreciate the attemptt. It is a U engine code but most decodes say thats a 3.0 You perform a service just by trying
Old Jan 19, 2022 | 10:36 AM
  #41
tmartenson's Avatar
tmartenson
Hi. I'm looking at a Ford LTL9000. VIN # 1FDYA90WXGVA28129
Thank you for any help.
Old Jan 19, 2022 | 05:36 PM
  #42
85e150's Avatar
85e150
Welcome to FTE!
1FDYA90WXGVA28129
1FD = Ford Motor Co USA, incomplete vehicle
Y = Class 8, air brakes, 33,001 to 55,000 lbs GVWR
A90 = LTL 900 diesel
W = Cummins NTC 230/240/250/270/290/300/444. 855 CID/14L 6 cylinder diesel (Should be a plate or sticker on the engine for the exact one)
X = check digit
G = 1986 model year
V = Kentucky Truck Plant
A28129 = serial number
Old Jan 19, 2022 | 06:19 PM
  #43
tmartenson's Avatar
tmartenson
X = check digit. That is the digit in the VIN. Does the X not mean anything in particular?
Old Jan 19, 2022 | 06:42 PM
  #44
85e150's Avatar
85e150
According to the 17 digit decoders and the Master Parts Catalog, it's just a check digit to be ignored. Not a command like "Go check that digit". Sorry for the confusion.
Old Jan 21, 2022 | 06:56 AM
  #45
tmartenson's Avatar
tmartenson
No problem. Thank you for your the clarification.
wharthog
Large Truck
Jan 5, 2021 06:09 PM
gdoakes
Large Truck
Feb 10, 2017 04:22 PM
bigblock466
May 20, 2015 06:22 PM
sth62691
15
Sep 20, 2011 03:41 AM
emt18967
13
Sep 16, 2011 11:04 AM
