Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
2001 Ford Lightening won't idle after mods..HELP ( race coming up)>>>
Old 03-29-2011, 06:39 PM
expy4life's Avatar
expy4life
expy4life is offline
Mods that I've made... The Truck will start without mass connected..With mass connected it will start and backfire ( if throttle is held open)and there is this pinging noise also.
Injectors..60lbs
Boost 20-25lb
Ported heads trick flow
3.4 whipple charger
Headers ( no cats)
2 fuel pumps ( 255 LPH)
Adjustable Fuel Pressure Regulators
Single Blade Throttle Body (big mouth)
SCT BA 3000 ( MASS AIRFLOW)
Lobe Separation 114...
Above are the mods that my cuz in the islands has done to his lightening..Now Truck starts but it won't idle... The truck is in the islands and its build for racing..
Could it be the computer???? Ideas needed as soon as possible cause major race is coming up..
Thanks
Old 03-30-2011, 09:05 AM
phil6608's Avatar
phil6608
phil6608 is offline
I probably shouldn't even ask this ,but, It dose have a good tune?
Could be a vacuum leak or the IAC might need to be cleaned or replaced.
Old 03-30-2011, 08:54 PM
patrickke's Avatar
patrickke
patrickke is offline
I think its in the tune as well, was your tune set up for these mods?
Old 03-31-2011, 01:12 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
+1. Who did the custon tunes? Why doesn't he make tuning adjustments?
Stewart
PS - Lightning, not Lightening.
Old 03-31-2011, 05:37 PM
expy4life's Avatar
expy4life
Any more ideas..It was tune to mods 3x and it still has problems.. It has no codes..
Anymore ideas.. what kind of mass should I use with this mods?
Old 03-31-2011, 06:24 PM
phil6608's Avatar
phil6608
phil6608 is offline
You said you have the SCT BA3000 correct?
That should be fine if your tuning is right.
Old 03-31-2011, 08:16 PM
patrickke's Avatar
patrickke
I would try someone Else's tuning contact Mike at 5Star tuning they can get you fixed up I'm sure
Old 04-06-2011, 03:46 AM
STOFFERJ's Avatar
STOFFERJ
STOFFERJ is offline
another vote for the tune being the issue
Old 05-03-2011, 09:03 PM
Merledude's Avatar
Merledude
Merledude is offline
Hi I really hope you have gotten your problem fixwd by now! would love to hear what the solution was. on the other hand I haven't read that any1 mentioned calibrating the Mass Air? def sounds like its lean if its pinging so I'd also lean towards a tuning issue.... sorry for the broken record, it also could have something to do with the Cats and EGR delete if thats been done....Good luck! Merle
small.block.ford.guy
11-18-2013 02:44 PM
JagerBlunt
08-17-2013 09:27 PM
boggerted
11-30-2011 06:49 AM
s.bittner
18
05-26-2006 02:24 PM
93BigBlackBronco
1978 - 1996 Big Bronco
03-30-2004 08:51 AM
Quick Reply: 2001 Ford Lightening won't idle after mods..HELP ( race coming up)>>>
