Sponsored by: Auxito
2003 ford f150..... Please help!!
Old Mar 29, 2011 | 03:04 AM
Kaboose82's Avatar
Kaboose82
My 2003 f150 has had the same problem for 10 months now and i can not figure it out. Here is what it is doing,..when i accelerate(especially up hills)the truck sputters, coughs, and misses. I have been trying to track down the problem for months. The list of things i have tried are as follows. Replaced fuel filter, replaced spark plugs, replaced spark plug wires, replaced catalytic converters, ran bottle after bottle of fuel cleaner etc. Thru. Any ideas of what could be causing this would be greatly appreciated... By the way, my mechanic says that it is NOT a coil pack!.................HELP!!!!!
Old Mar 29, 2011 | 03:44 AM
Eric Landstrom's Avatar
Eric Landstrom
Carbon build up on the back side of the throttle plates? Bad throttle position sensor? Bad mass air sensor? Bad MAP?
Old Mar 29, 2011 | 05:25 AM
docgj's Avatar
docgj
Ethanol gas? My wifes 2006 ford 500 had a similar problem. Only it would die than after sitting for a few minutes you could proceed. Shop found the ethanol had gelled in the bottom of the tank. Had to drain tank. I know there are treatments out there (Expensive) that will help clean the junk out of the tank and fuel system. Got to love the new gas!
docgj
Old Mar 29, 2011 | 05:41 AM
n5926g's Avatar
n5926g
Welcome to the forum!
You might want to re-post this in the proper year range of the forum You will likely get more answers directly related to your truck.
Old Mar 29, 2011 | 06:22 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to new forum.
Old Mar 29, 2011 | 10:37 AM
Joe Finn's Avatar
Joe Finn
Despite what your mechanic says, it sounds like a bad COP. Have the codes scanned and see if there are any pending codes. If there aren't any, try to make the truck "sputter" for as long as possible and see if you can force it to throw a CEL code. You could also buy one COP and try it in each cylinder (1 in 8 chance).
Old Mar 30, 2011 | 02:27 PM
LxMan1's Avatar
LxMan1
What engine do you have because the V8's do not have plug wires!!!!!
Old Mar 30, 2011 | 03:03 PM
Kaboose82's Avatar
Kaboose82
2003... Replaced the boots.
Old Apr 1, 2011 | 10:31 AM
FORDTRUCKS4488's Avatar
FORDTRUCKS4488
Same problem on my 2001 Supercrew. I tried everything you tried, I had a broken wire for a fuel injector and it was a $10 fix. It could be your injectors. That was my next option. You can get 8 new ones on ebay if needbe for $100. Just as good as OEM.
Old Apr 1, 2011 | 10:33 AM
FORDTRUCKS4488
Also try to look at little things such as, PCV valve, IAC Valve, TPS(Throttle Positioning Sensor)
Old Apr 1, 2011 | 09:47 PM
jirwin's Avatar
jirwin
I am having similar problem. Sputter, throws a code that they say is the CPS. Replaced with Motorcraft, still throws same code. Replaced Plugs and cleaned throttle body. Any suggestions. Sorry for hijack
Old Apr 11, 2011 | 02:26 PM
Kaboose82's Avatar
Kaboose82
Finally Fixed!!!!
Took truck to ford dealership. Even though there was no code, their computer picked up on a bad injector coil. Replaced for $100. Thanks everybody and good luck!
Old Apr 13, 2011 | 04:47 PM
jirwin's Avatar
jirwin
Originally Posted by Kaboose82
Finally Fixed!!!!
Injector coil is different from Coil On Plug?
2003Navi
Aug 25, 2010 09:20 AM
LightningWolf
Jan 16, 2010 04:54 AM
mhare
1997 - 2003 F150
Apr 23, 2009 09:56 AM
F250_
17
Sep 26, 2007 03:18 AM
ZonaNavyStar
Aug 25, 2007 11:26 PM
