are there any precations i can take to avoid breaking my glowplugs b4 i remove them??
If you have a problem getting them out, Put a pair of vise grips on it and twist till it come out. worst case you can just reinstall the bad one.
You will be fine just do it. If you have problems post them up and we can help you thru it.
There is nothing you can do right now. Just get in there and see how they come out.
Had two that worked out hard for me. I think they had been bad for a while and carbon had built up on the tips. What I did was when it started getting hard to turn I would reverse direction for a full turn to let the carbon fall off. Probably had to do that 10-12 times per glow plug. Took a little while longer to get them out but didn't break either of them. Just my 2 cents.
Brooks
Brooks
-Some people uses something like WD-40, PB blaster or something else (like a marine product against the carbon that I dont remember)
a couple of days before pull them out.
-When you install the new ones put some antisieze in them.
-DONT install AUTOLITES!!!
taandctran
05-16-2010 12:25 AM
ramblemutt
08-18-2008 10:05 AM
