bypass glowplug controler?
Old May 15, 2010 | 03:37 PM
taandctran's Avatar
taandctran
Is there any way to teperarly bypass the glowplug controler? I think that is my problem but want to make sure before I shell out anymore money. truck is a 89 7.3
Old May 15, 2010 | 06:51 PM
oreocreaming's Avatar
oreocreaming
ya, you can start by jumping from the power in to the switch prong to see if that clicks on. second, you can run a thick jumper wire from the positive in to the coil on it. it draws a ton of amps so the wire might get pretty hot quick. that will let you know if its the box itself or just the solenoid
Old May 16, 2010 | 12:25 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
On a 89 ... All you need to do is remove the white wire on the Relay (on top of controller) and ground the terminal on the relay you removed it from ... WARNING!!! This will activate your glow plugs as long as you have the key on...
To do a manual button setup, Use a push button, ground one leg of the push button, the other leg goes to the terminal on the relay you removed the white wire from.
When the key is on, hold that button for 10 seconds, start truck.
You might want to read this: Glow plugs, 87 thru 94, new style
-Enjoy
fh : )_~
Kingkong0192
Nov 22, 2016 04:04 PM
1972RedNeck
Jan 30, 2016 08:19 AM
chetspencer
Jan 24, 2016 09:07 PM
78sharpshooter
26
Dec 25, 2013 09:01 AM
1978fordf250
15
Aug 2, 2008 08:18 AM
