272 start-up
Old Mar 26, 2011 | 07:15 AM
telefunkken's Avatar
telefunkken
272 start-up
truck (56 f-250) has been sittin for awhile( 93 inspection sticker on windshield). i want to check cyl. comp. my question is what (if at all) should i put in the cyl. before i hand turn the engine? thanks for any help.
Old Mar 26, 2011 | 09:56 AM
46yblock's Avatar
46yblock
If it were me I would shoot in 200 cc of 5W30 oil, let it sit a day, and try turning over manually. If stuck try going back and forth on the damper bolt without excessive torque. If still stuck you could add some WD40. Make sure to drain and flush old gas before starting or else stuck valves are a high possibility. Also change oil.
Old Mar 26, 2011 | 03:51 PM
telefunkken
ok 46, is that per cyl. and how much is 200cc in standard? i'll use gas can when i go to start it, thanks i'll let you know how it went.
Old Mar 26, 2011 | 06:14 PM
46yblock's Avatar
46yblock
Approx. 30 ml per ounce. And I meant per cylinder. For stuff like that I have some large 60 cc syringes. Nothing magic about the amount, a little more or less. If it is stuck bad you may need to inject enough to fully cover the piston/rings. Then when it does turn over be ready for a mess, and have all the spark plugs out.
Old Mar 27, 2011 | 11:54 PM
charliemccraney's Avatar
charliemccraney
It wouldn't hurt to remove the distributor and turn the oil pump with a drill for a minute or two to distribute oil to the bearings before you turn it over.
Old Mar 28, 2011 | 04:32 PM
telefunkken
ya know, the drill on the oil pump crossed my mind to prevent dry-start, i'll do it but what is the correct way,what i mean is what will the oil pump accept. hey 49 i don't know if the engine is seized, i was going to turn it a little with a 3/4 rachet after i soak it with the 5w30,what do you think.
Old Mar 28, 2011 | 06:13 PM
46yblock's Avatar
46yblock
Yes that would be good. To prime with drill, chordless or non chordless, a long hex shaft is needed to reach the oil pump drive shaft. An old dist shaft or a tool that used to be available at auto stores, or a long flexible hex drive found at good hardware stores. Make sure to set drill for reverse. If a valve cover is taken off you can prime until oil is seen dripping from the rocker assembly.
fordinmudd
1983 - 2012 Ranger & B-Series
Nov 16, 2010 11:17 PM
pm5471
Jun 14, 2010 12:15 AM
6578trk
Nov 24, 2007 02:38 PM
hillview
Engine Swaps
May 23, 2005 12:23 AM
jmms
1997 - 2003 F150
Aug 18, 2003 02:49 PM
