door hinge pins
Old Mar 25, 2011 | 06:50 PM
mercman65's Avatar
mercman65
door hinge pins
does any one know how to get the pins out of the door hinges on the 48-52s ??
Old Mar 25, 2011 | 07:59 PM
arrowheadfred's Avatar
arrowheadfred
pins
I had to take the door off by taking the 3 screws out of the cab and use a torch to heat the pins and beat them out. PAIN IN THE A$$. They make a tool but it ain't much good on the pins that have been there for 60 years. I also had to drill one out. Use a smaller bit and drill down the middle then heat it up and beat it out. GOOD LUCK
Old Mar 25, 2011 | 08:24 PM
Doc's Avatar
Doc
I soaked mine with PB blaster for several days and got my dad's help. We took a big long punch and a pair of channel lock pliers. We held the punch with the pliers (so we could swing away and not lose a hand) and knocked the living hell out of it about 10 or 15 times. When it starts coming, it will be very very small changes at first and it will not "let go" until it clears that entire head and all those splines or grooves. You can heat em and get em out too.
Old Mar 25, 2011 | 08:30 PM
Old F1's Avatar
Old F1
Take the door (hinge) off if you can, as the pin has a slightly larger diameter at the top so the pins have to come out from the bottom (ask me how I know this).
Mega heat, big hammer, bent punches, broken hand, all good.
Old Mar 27, 2011 | 11:11 AM
56viet's Avatar
56viet
I used an air hammer, with a small punch tip, and they came right out. Maybe just lucky,but had no luck at all with a hammer and punch.
Old Mar 27, 2011 | 11:53 AM
Doc's Avatar
Doc
LOL. I tried an air hammer and got nowhere. But a hand punch and some really hard hits got mine. I guess every truck is different.
Old Mar 27, 2011 | 01:25 PM
The Great Jose's Avatar
The Great Jose
Great Thread
I have been lurking in the weeds after joining and haven't said much. This is a great site for info...thanks, Joe
Old Mar 27, 2011 | 03:39 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Don't lurk in the weeds man! It creeps me out! LOL get up brush yourself off and get on board! And yes it is a GREAT site!
Old Mar 27, 2011 | 07:02 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I have succesfully oiled and used a punch and hammer, but there is now a hinge pin extration tool avaiable , i got out of one of the catalogs, im not sure wich catalog, but it should be easy to find. it worked well for me. good luck (JIMMY)
Old Mar 27, 2011 | 07:09 PM
agronomistont's Avatar
agronomistont
I got mine out last week. i ground the bottom edge flush then drilled a hole in the centre to hold the punch. Then i heated them a couple of times and quenshed them with water between heatings then hit them with a bfh one came out easy thye other a little harder, but they are out now.
Old Mar 29, 2011 | 09:11 PM
mercman65's Avatar
mercman65
thanks for the reply guys looks like i have some fun ahead of me
1LIFE
Jan 10, 2015 08:09 PM
Sabes76
Apr 1, 2013 12:31 PM
danyzf95
Mar 15, 2009 09:32 PM
mike330
Jan 15, 2008 07:46 PM
fleetline46
Jul 2, 2005 01:38 PM
