it sounds like it is missing
Old Mar 25, 2011 | 06:00 PM
brwolfjr's Avatar
brwolfjr
I walked around my truck after starting it this morning and the exhaust did not sound normal to me. It sounded like it was missing. Could I have an injector on they way out?
Thanks
Ben
Old Mar 25, 2011 | 06:17 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Could have been your EBPV.
(Assuming automatic...) while driving in O.D. with TC locked (over 40 mph-ish), try and accelerate without causing the transmission to downshift. If your truck accelerates from 45 to 60 without shaking then all your injectors are working. If you were running on 7 cylinders, the engine would shake and struggle to accelerate.
Old Mar 25, 2011 | 06:40 PM
brwolfjr's Avatar
brwolfjr
No ebpv. Truck seems to run OK. About a month ago, ran real low on fuel and the truck was shaking real bad with no power. I wonder if I damaged an injector from either air or dirt.
Old Mar 25, 2011 | 06:43 PM
Shake-N-Bake
I have heard tales where owners have run their fuel low and picked up sediment which clogged the screens in the pickup assembly (in the tank) and/or the screen at the pump.
Do you have a fuel pressure gauge by any chance? Is your pump louder than usual?
Old Mar 25, 2011 | 06:51 PM
brwolfjr's Avatar
brwolfjr
fuel pump sounds the same and a gauge is on my wish list when I do the 650 lower dash
Haywire-Powerstroke
20
Jun 3, 2015 08:10 PM
2020
May 26, 2015 07:16 PM
Jarret1224
Apr 26, 2014 01:45 PM
Lewis90i6
Electrical Systems/Wiring
13
Feb 15, 2014 07:45 AM
Redleg319
Mar 18, 2004 09:22 PM
