stock air filter question
Old Mar 24, 2011 | 10:27 PM
jackstraw's Avatar
jackstraw
no 6637 or AIS here. perhaps convince me.
anyhow I do like to get the regular filters with the deeper pleats. usually takes a special order, frex Purolator sells one as a premium version.
anytime I let someone get a hold of my truck, they look at the air filter and ask me why I use those. why do I is my question I guess. the deeper pleat seems like it should be better. is it?
Old Mar 24, 2011 | 11:07 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Have you had our oil analyzed? If so, what is your silicon readings? My guess is that your filter choice is fine and it probably does the job. The thing to watch is how well the factory airbox seals. Take a look at your turbo wheel and see what it looks like. Also check the inside of the upper airbox lid for any signs of dirt.
Old Mar 24, 2011 | 11:19 PM
Bonanza35's Avatar
Bonanza35
I have a neighbor that is into banks heavy. He just went with the deeper filter on his stock box because the banks oil insert for the stock box filled up to easy and under heavy pulls, 5th wheel, it didn't flow. He says so far this works for him.
Old Mar 25, 2011 | 09:06 AM
MiamiPSD's Avatar
MiamiPSD
If you like the stock set-up, look into the Ford AIS system. Best of both worlds.
Old Mar 25, 2011 | 09:17 AM
cj45lc's Avatar
cj45lc
What he said, the AIS is a great filter per all the info out on it & fits & looks like Ford put it on at the factory.
I'm happy with it all the way around...JMO
Old Mar 25, 2011 | 07:05 PM
dagren99's Avatar
dagren99
Don't have to special order them around here - most parts houses keep them on the shelf. Been running the purolator or napa "deep pleat" filters for a while w/ a stock box. UOA comes back with good Si #'s. I can get the p/n on both in the morning and post it if need be. Think the actual oem app for this is the van chassis w/ the 7.3
diesel_dan
Jan 16, 2018 12:10 PM
Saxon
Jan 26, 2013 05:51 PM
tlh06f250
6.4L Power Stroke Diesel
Apr 30, 2008 12:13 PM
mybigredford
15
Apr 26, 2007 07:25 AM
Mwachel
Dec 23, 2005 10:34 AM
