Fuel Injector Modular
Old Mar 24, 2011 | 11:06 PM
Barney58's Avatar
Barney58
My 2004 F 250 crew cab 6.0 Diesel just doesn't turn over, no fire when turning ignition on. It sounds like a fuel pump but dealer says its the modular. What has others experienced with this issue????
Old Mar 25, 2011 | 09:08 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I'll give you a bump to the top. Good luck.
Old Mar 25, 2011 | 02:48 PM
pjerrn's Avatar
pjerrn
You should Post in the 6.0 section
need a little more of what is going on. Does it turn over and not start? there is a no start folder in the tech section you can go through that will help you.
Old Mar 25, 2011 | 03:38 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
tmaglin
Modular V8 (4.6L, 5.4L)
Aug 8, 2012 08:30 AM
eightarches
Modular V10 (6.8l)
Nov 15, 2009 09:09 PM
Marc150
General Automotive Discussion
Mar 21, 2005 05:55 PM
christop43
37
May 3, 2003 12:18 AM
