Modular???
Old Jun 23, 2012 | 07:39 AM
tmaglin's Avatar
tmaglin
Modular???
Just curious as to why these engines are called modular. How do they differ from a non modular engine?
Old Jun 23, 2012 | 07:45 PM
tablesaw's Avatar
tablesaw
I read somewhere that the factory they are made in is a modular setup. They can easily change out some tooling and make all the mod motors in the same place.
Old Jul 12, 2012 | 12:39 AM
Pugnasty's Avatar
Pugnasty
In my industry, modular means that you can take apart a section of the engine/motor without pulling everything else apart. Best example I can think of that would make sense in this case would be if you could pull the engine and split it in two. Otherwise, it doesn't make sense to me either.
Old Jul 12, 2012 | 05:22 PM
galaxie641's Avatar
galaxie641
Correct they are all based off the 4.6L, 5.4L has a longer stroke and a bigger block to accommodate it, the 6.8L is just a 5.4L with 2 more cylinders. The V8 heads interchange if made in the same plant. Bore is the same on all 3. All cost cutting moves, there was supposedly also going to be a V6 that would be a 4.6L minus 2 cylinders that never quite happened. Not like they haven't done it before but this time they just named them what they are and tried to share as much as possible. 390 is a stroked 360, 351M is a de-stroked 400, 460 is a stroked 429 etc etc.
Old Jul 13, 2012 | 06:22 AM
tablesaw's Avatar
tablesaw
I have the 5.4. Wish I could purchace those two other cylinders as an aftermarket add on.
Old Jul 13, 2012 | 03:40 PM
Pugnasty's Avatar
Pugnasty
Now that would be something...
Old Jul 14, 2012 | 06:38 PM
hans2112's Avatar
hans2112
Modular refers to the plant design, not the engine. Just a nickname of sorts. For me, modular is a greek for the crappiest engine ever made
Old Aug 4, 2012 | 02:39 PM
Trail_Rider's Avatar
Trail_Rider
Since these are theoretically, basically the same engine, are they interchangeable with one another. In other words is a 4.6 a bolt in for the 5.4? Are the trannies a direct swap between the two engines?
Old Aug 8, 2012 | 08:30 AM
dad2bandm's Avatar
dad2bandm
From Wikipedia...
Ford Modular engine - Wikipedia, the free encyclopedia
"The Ford Modular engine is Ford Motor Company's overhead camshaft (OHC) V8 and V10 engine family, which has been produced in 4.6L, 5.0L (Cammer, Coyote), 5.4L, 5.8L and 6.8L variations. Contrary to popular belief, the Modular engine did not get its name from its design or sharing of certain parts among the engine family. Instead, the name was derived from a manufacturing plant protocol, "Modular", where the plant and its tooling could be changed out in a matter of hours to manufacture different versions of the engine family.<sup id="cite_ref-0" class="reference">[1]</sup> The Modular engines are used in various Ford, Lincoln, and Mercury vehicles. Modular engines used in Ford trucks were marketed under the Triton name from 1997–2010 while the InTech name was used for a time at Lincoln for vehicles equipped with DOHC versions of the engines.
olblue77
May 31, 2016 04:43 AM
less
47
Jul 13, 2009 09:28 AM
jdawwggin25
Oct 7, 2004 06:44 PM
BrentKasson
Modular V8 (4.6L, 5.4L)
Mar 27, 2004 10:35 PM
SSvec
Mar 24, 2002 06:08 AM
