Chip issue..
Old Mar 24, 2011 | 04:07 PM
Krisx125's Avatar
Krisx125
Chip issue..
Borrowed a TS chip from a friend. Whenever i do a hard pull to about 2-2500 and let off she dies...Watch and comment..
YouTube - ts chip
P.s dont mind my buddy at the end with the "please explain" lol
Old Mar 24, 2011 | 04:10 PM
BuckHammer's Avatar
BuckHammer
I think it's interesting how the speedo jumps up to your current speed when you start it from neutral. Run an OBD scan and tell us what it says.
Old Mar 24, 2011 | 05:25 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Are you sure that you have a good connection to the PCM? That can cause some weird problems. Otherwise, the chip could need to be retuned. You could have a bad file.
Old Mar 24, 2011 | 07:54 PM
Krisx125's Avatar
Krisx125
Just checked and it seems to be in there pretty well...Is it bad to run it if it needs a reburn? or a bad file?
Old Mar 24, 2011 | 08:35 PM
strokin'_tatsch
I haven't watched the video yet, btw. I cannot view youtube at work. LOL. When you cleaned the J3 port, are you sure you got it good and clean? Didn't go too far? I'd pull it out, have it checked, and try it again. If it still stalls, I'd check the J3 port.
Old Mar 24, 2011 | 08:40 PM
pjwoolw's Avatar
pjwoolw
It' runs normally without the chip? If so I'd leave it out. What was the chip in before?
Old Mar 24, 2011 | 08:41 PM
Krisx125's Avatar
Krisx125
alrighty well steves up here tomorrow...we'll look further into it. thank trav!
Old Mar 24, 2011 | 09:06 PM
Action4478's Avatar
Action4478
This is a simple test . Did you try it ?................................
Old Mar 24, 2011 | 10:53 PM
Krisx125's Avatar
Krisx125
lol sorry didnt see that post, yes it runs fine without the chip...and it runs well with the chip also...just when you get on it and let off sumtimes it stalls...But my fuel mileage is sooo much better!
Old Mar 24, 2011 | 11:24 PM
strokin'_tatsch
I just watched the video. Programming problem most likely. Looks like when you let it drop to idle like that the tuning is letting ICP drop too low and it dies. Check that if you want. When we were live tuning, we got one tune that would let ICP drop to like 200psi when I ran it hard and let off the throttle. Never let it drop to idle like that to see if it died, just had him fix it.
hav24wheel
15
Sep 16, 2016 06:32 AM
sean9049
32
Nov 8, 2015 12:38 AM
Thoroughbred Diesel
30
Oct 24, 2014 02:38 PM
dmanshane
Apr 24, 2014 08:16 AM
f350rebel7788
25
Mar 27, 2012 12:32 PM
