Diesel Fuel Leak REPAIRED!
All,
Just wanted to comment on this problem as it seems to be common. I've got a 2000 F250 with a bit over 210,000 miles on the clock. After a hard freeze (at least for us here in Louisiana) I walked out to go to warm the truck before taking the kids to school and heading for work when I noticed a drip coming from the engine. At first I thought it was some sort of condensation but after taking a look found it was fuel. I turned the truck off and we moved to the Suburban. I've had my truck parked for about a month. I finally worked up enough energy and dug into it last night after work. Using this web site and replacement O-rings from Guzzles I'm back on the road with no leaks. This really is an easy fix. The hardest part was getting my hands in there to get the fuel valve off. At any rate, if you are experiencing a fuel leak, the first place you should look is this valve on the back of the fuel bowl. The part is less than $10 and really is simple to repair.
Thanks to all who have posted about this. This forum is a huge help...now if I can figure out the slop in my stearing I'll be good to go!
Thanks...I typically lurk and don't post all that much. This is my second F250 and I've gotten a lot of help from this site. Great resource for our trucks. This is my first Diesel and it's been a great truck so far. Pulls my jeep and camper like a mule...about 9,000 pounds.
All,
Welcome to FTE.
Giuffsa
08-24-2014 10:53 PM
SkySkiJason
18
09-20-2010 07:39 AM
