92 F150 inline 6 fuel problems
Old Aug 22, 2014 | 10:46 AM
Giuffsa's Avatar
Giuffsa
Good morning!
I just bought this truck. Runs pretty good. FI. 99k. 2 tanks. Valve cover gasket leaks. Great shape.
Problem is fuel like most other of this generation. Connected pressure Guage, I only get 20 psi with the first koeo, 35 with the second or third. The fuel pump also has a hard time keeping up at start up (I got under the truck to listen for the noise. It spins up, but you can here her struggle to keep up). Running I get about 38psi.
Tank switch works well with the front tank, but I get no noisewhen I switch to the rear (Nothing under the truck either) I'm going to use a volt meter this weekend to trace wires.
I'm headed to the junk yard Sunday to maybe get a few parts to see if anything needs to be replaced. I also planned to come to my shop and pull the bed off (thinking it would be easier than dropping both tanks) overhead cranes and such) to pull the fuel pumps out and check if they could be clogged.
Question: does the rear tank have a pump, or just a transfer pump?
Could a bad pump cause the low psi during startup and during the "catch-up" right after start up?
The guy who owned the truck before me removed the air box and put a mesh screen (damn Louisiana cajuns) over the intake. He said the airbox made the truck run bad... smh
Last question; looking at the motor, top left corner is a little cylinder with a hose coming out of it. It has a little blue actuator arm. Wtf is that thing? No diagram online has it labled and I'm going buy the Hanes book today.
Thank anyone and everyone for their time and I look forward to many fun conversations. I've read many posts by you guys. If there are treads that can answer my questions, please post links. I'm kinda new to the forum thing.
Salty Squid
Old Aug 22, 2014 | 01:20 PM
Giuffsa's Avatar
Giuffsa
[QUOTE=Giuffsa;14603822]Good morning!
Bought the book and the valve cover gasket. Autozone was less than helpful with questions
Old Aug 22, 2014 | 04:21 PM
joegeds's Avatar
joegeds
That thing is some kind of vacuum operated actuator. It opens/closes a vent door, but I am not sure what activates it. There should be a white vacuum hose going into it, but that white hose always gets very brittle with age and most times it's not there.
Old Aug 22, 2014 | 08:11 PM
Giuffsa's Avatar
Giuffsa
Dead on. The hose is not there. Thanks for the input.ill start the research and go through the Haynes book tonight. Maybe I can find something along those lines. Happy Friday
Old Aug 23, 2014 | 01:28 AM
curtisbutlerjr's Avatar
curtisbutlerjr
that thing
that thing is the vacuum actuator for hvac dampers in the dash. look for thread "environmental vacuum lines" it will give you diagram.
Old Aug 24, 2014 | 10:53 PM
Giuffsa's Avatar
Giuffsa
on to the next thing, i took off the valve cover and discovered a half inch of crud on everything. after tinkering with it, i took a waterhose and sprayed all of it out, pretty much did a fresh water wash-down on everything.
i put detergent free oil back in, and started it. it started rough, but leveled out after it figured out what was going on... i didnt run it long. it was bad enough to not know how the hell it was moving oil in the first place
kgrasso
Oct 25, 2015 10:39 PM
paintdrying
Aug 29, 2012 10:37 AM
fordsrawesome
Dec 10, 2011 08:00 AM
007bronco
Oct 10, 2004 05:41 PM
classic79
Jul 10, 2003 03:00 PM
