Sponsored by: Real Truck
Changing steering damper
Old Mar 23, 2011 | 05:51 AM
Reg B's Avatar
Reg B
Just put a readylift leveling kit on my 09 f-250 and put 35's on now a small shimmy. Should I upgrade the single or go to dual...
Old Mar 23, 2011 | 12:19 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
Wink
Here is a link that may help you in your choice.
https://www.ford-trucks.com/forums/1...tabilizer.html
Old Mar 23, 2011 | 06:15 PM
tinman565's Avatar
tinman565
Sir...I just put a dual system on my truck. I got it from Rough Country. I think it was like $125 ? Awesome setup...easy to install...looks great (get the boots in your favorite color)...and best of all, makes the steering feel great.
Old Mar 23, 2011 | 06:50 PM
402xjeeper's Avatar
402xjeeper
Your caster angle is off, the level kits change it, it may be within spec, bu, you have lost a little bit of caster if you did not have it reset, it my require an eccentric kit, I have had good luck with KYB replacement stabilizeres.
Old Mar 29, 2011 | 11:47 PM
Reg B's Avatar
Reg B
caster
Can u explain caster problem to me dont know ...thankyou
Old May 4, 2011 | 09:57 AM
402xjeeper's Avatar
402xjeeper
The level kit rotates the axle foreward when it lifts the truck, caster is the angle of the line drawn from the lower ball joint to the upper, when the truck is leveled this angle is lessened, if you restore the angle back, then it will track properly.
ARK Ranger
Nov 6, 2012 10:28 PM
sprintcarcrazy
2004 - 2008 F150
21
Jan 16, 2004 11:36 PM
vettehauler
Dec 3, 2002 05:34 PM
mk
Jul 30, 2002 04:29 PM
paveslave
May 26, 2002 05:03 PM
