I'm going to upgrade my steering stabilizer and i'm debating between an upgraded OEM (Bilstein 5100) or a dual Rancho setup. The cost is about the same, but was curious about the performance differences.
The dual systems are typically recomended for large or larger than OEM tires. If your comparing a single Bilstein to be installed in the OEM location against the dual Rancho mounted to the steering link, it may depend on a couple of things. What series Rancho comes with the set-up, Hydraulic or Gas? A gas shock will perform better than the hydraulic but you probably wont feel the difference in your non-performance (im assuming) application.
If your looking for good looks as well you may want to go with a dual system and just leave your OEM one on. The dual stabilizer may help minimize ball-joint, tie-rod and tire wear. Having all three may increase your steering effort abit and could arguably create future steering box issues. I have all three and havent had any issues. Ultimately a dual gas system would be the best and most expensive but is typically overkill (from a functional standpoint) for most street driven trucks.
Mine is Rough Country.
Where are you looking for these? I need to do something soon because I think I'm on my original dampener.
My truck came with one stock, i replaced it with a single rancho one. My friends 99 4x4 looked like it had the mount there but the metal looked broken and there wasnt one there so he added a dual setup by skyjacker. he told me it fixed his drifting problems on the highway and he likes it
New to the board and just impressed by all the knowledge here as well.
