PUTTING IN 302 DISTRIBUTOR
Old May 19, 2002 | 07:15 PM
paveslave's Avatar
paveslave
Old May 25, 2002 | 04:22 PM
86F150TRUCKDUDE's Avatar
86F150TRUCKDUDE
O kay...get the engine to top dead center....can I use a compression gauge? is it accurate enough??
How and what do I drop it in.....how can I be sure that I hav TDC? I need some help....seems simple...but i have left this undone for a while now....I cant seem to get it right....are there any web sites with pictures to help???man that would really help
Old May 26, 2002 | 12:58 AM
Wilber15's Avatar
Wilber15
If it ain't broke.....change stuff till it is!
What works to find TDC, is take out the #1 plug and use a plastic pole to set down the plug hole. when u turn the crankshaft, wait till the plastic pole rises all the way up. then u know it's top dead center. thats how we do it in our high school auto shop.(but actually, we use screw drivers).
Old May 26, 2002 | 01:33 AM
Mil1ion's Avatar
Mil1ion
The piston goes to TDC twice in a 4-stroke engine.
When it expels all the exhaust gases and once when it compresses the mixture ready to burn for the power stroke.
Wiber neglected to mention it should be on the TDC just before the power stroke.
To determine power stroke on the Number 1 cylinder >the easiest way is to pull off the valve cover and watch the intake valve close> Just after that the piston arrives at TDC for ignition.
At this point the distributor rotor should be pointing at the #1 position.
To achieve this you lower the distributor with the thought in mind that the shaft will be turning into position as it engages the gear splines on the camshaft.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 26, 2002 | 09:54 AM
rocky2's Avatar
rocky2
Or put your finger in #1 spark plug hole turn engine over with a wrench on crank pully bolt and turn in proper rotation and when you start to feel compressed air exiting cylinder then line up timing marks on pully to 0 then put in dist pointing to #1 on cap with advance facing the right way.
Old May 26, 2002 | 05:03 PM
Franklin2's Avatar
Franklin2
Do the above procedures. When you think you have it just right, but the dist lacks a little bit of seating all the way, you might have to take it out again, and turn the oil pump shaft down in the block with a socket on an extension just a little bit, and then try it again.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
walterdanek
16
Feb 16, 2001 07:56 PM
