My engine hasn't had the greatest engine vacuum since I put the new head, valves, rocker arms, etc. in. It's always had an odd oscillating sound to the engine too.
After I finally fixed the lifter tick this weekend with some new lifters, I noticed the vacuum was really acting up. I'm not quite sure how to diagnose this, but I'm thinking a stuck valve of some sort.
Here's some videos:
Idling at 1000 RPMs. You can see how it "unsticks" itself, and then sticks from time to time. I also do a few revs at the end.
Silly question, did you ever replace the intake/exhaust manifold gasket? I seem to recall you reinstalled a MrG that had been run for just a short while.
No, I haven't replaced the gasket yet. It's oddly on back order, so it's taking its time. I just thought this was too weird of behavior to be associated with just that.
The MrG 260. like all "header" gaskets, start out fairly soft to conform to the surfaces, but after getting heated up, they start to harden. Once they have hardened from even 1 heat cycle, they can be nearly impossible to get a good seal on.
Just one of the many reasons I don't agree with the recommendation of using this gasket. Exhaust leaks aren't that big of a deal. Intake leaks are.
I didn't know that about the MG 260. I like how well it seals, but it's a bummer it's a one time deal. A lot better than the Clifford though. I had to use a chisel and wire wheel to get that thing off.
I'll try a different PCV valve, and see how it responds once the gasket shows up.
I'd just never seen an intake leak do this before (and I've had my fair share of them!) so I wanted to be sure it wasn't something more drastic.
The way the vacuum seems to self correct and how the exhaust just gives a random pop now and then seems more ignition to me. I would look at dirty cap/rotor terminals, dirty advance weights, maybe even a small partial bind of the distributor shaft. Maybe try new wires even, I suppose it's possible the old ignition is too tired to keep up with the air charge of the new head.
I had the bouncing needle syndrome and got it figured out.
My situation was:
I'm running a MSD Blaster Ignition, coil, and wires.
I set my plug gap to .055 as recommended as the "perfect" setting.
I hooked up my vacuum guage and the needle was bouncing/vibrating like in your video.
I re-gapped my plugs to .060 and the vacuum needle smoothed right out.
My random "pop" also disappeared.
Long story short, I'd be looking at your ignition system.
Interesting thought, and reminds me that when I got done getting everything back together, I gapped my plugs back to stock instead of the 0.050" they were before the cam.
