Dancing Vacuum Needle
Old Apr 8, 2011 | 12:22 PM
  #61
AbandonedBronco's Avatar
AbandonedBronco
Originally Posted by Rogue_Wulff
Try another simple test. Back off the rockers just a bit. It could be as simple as the valve stems being a hair "too long" due to the seats having been ground. Generally, during a valve job, the tip of the valve stem is ground down as needed, to make up for it sitting a bit deeper in the seat. Perhaps the shop didn't quite get that part right.
Would this have been noticeable when I measured valve clearance when my lifters were bled down?
Old Apr 8, 2011 | 12:52 PM
  #62
Rogue_Wulff's Avatar
Rogue_Wulff
Should have been. If the clearance was tighter than normal, then we may be on to something here. If it was fine, then could be related to valve sealing.
If the tips of the stems were a bit too tall when installed, it would lead to valve sealing issues, particularly after the engine is warm.
Could also be lifters pumping up once the engine is warm.
Old Apr 8, 2011 | 01:04 PM
  #63
AbandonedBronco
I measured the gap between all the valve stems and rocker arms on all of them with empty (bled down) lifters. 0.100" was the minimum, 0.200" was the max. 0.125" - 0.175" was preferred. I believe the lowest was 0.135" and the highest was 0.160". All very well in spec.
The popping is pretty much the same whether the engine's warm or cold.
Old Apr 8, 2011 | 01:26 PM
  #64
Rogue_Wulff
Silly question. Were the lifters used during the clearance test the exact same lifters in use now?
The valve stem length is critical on these ford engines with non-adjustable valvetrain. Even more so when the head and/or block has been decked, particularly if the entire valvetrain is being replaced with new parts (rockers, pushrods, cam & lifters) rather than older parts with a little wear on them.
I still think a good test would be to back off the rockers .5-1 turn, and see if the popping goes away. If it does, then you have a solid answer. If not, then the valves just aren't sealing, and the head will most likely need to come back off.
Old Apr 8, 2011 | 01:31 PM
  #65
AbandonedBronco
Yeah, they were the same lifters.
I'll give the test a try and back them off. They're the later pedestal style, so I'm not sure how well it'll work. It'll give me an idea though.
That does beg the question. If the lengths on something were off, why would the problem surface as time went on? There's always been somewhat of an issue with ticking (and the vacuum oscillating) but this popping is a new development. Wouldn't it have done it from the start?
Old Apr 8, 2011 | 01:53 PM
  #66
Rogue_Wulff
If the valves were *barely* sealing at the seats, they could actually be starting to "burn" the valves and/or seats. As the combustion leaks out, it can accelerate/intensify the leaking.
Also, as the valves start lapping themselves in, it actually wears away a small portion of both the seat and valve, where they meet. Lapping compound for hand lapping the valves, is gritty paste that polishes the mating surfaces. This wears away a very minor amount of material from both surfaces.
Old Apr 8, 2011 | 05:17 PM
  #67
dustybumpers's Avatar
dustybumpers
I'm also thinking maybe a broken valve spring, and only acts up when it's being pushed under power.
Old Apr 8, 2011 | 05:44 PM
  #68
Rogue_Wulff
A very viable possibility.
Old Apr 8, 2011 | 07:05 PM
  #69
F-250 restorer's Avatar
F-250 restorer
AB--I ain't NEVER going to Vegas with you. I'm sure there's a country Western song here somewhere.
I hope you find the problem. Could there be a small crack in that head?
Old Apr 8, 2011 | 08:08 PM
  #70
dustybumpers
why not? he'll stand under the black cloud, you watch the rainbow, and get the pot of gold.Sorry. couldn't resist. I don't think crack in the head, because it is not doing it all the time, and I can't get past the noise it's making, that is definately mechanical.
Old Apr 9, 2011 | 01:48 PM
  #71
BaronVonAutomatc's Avatar
BaronVonAutomatc
If there's something too long in the valve train, try some shims under the rocker pedestals. I bought a set of roller rockers for a SBF that came with two different thickness shims, but when I had to stack them to get the right preload I just bit the bullet and got shorter pushrods...
Old Apr 13, 2011 | 03:21 PM
  #72
AbandonedBronco
You guys crack me up. But hey, you can only have so much bad luck, right? Maybe I've already used all mine up.
Well, the problem's continually getting worse and worse (less and less throttle required) so I'm thinking a valve is burning or something. I imagine I'll have to pull the head here soon and have it R&Rd. Hopefully, after that, I'll be done with all of this.
As for the valve springs, would it be pretty easy to see if one's broken? They're brand new Comp springs, I'm not sure how one would have broke.
(Also, it's definitely not a mechanical knocking.)
Old Apr 13, 2011 | 03:58 PM
  #73
82_F100_300Six's Avatar
82_F100_300Six
have you checked the linkage for the carb? sounds to me like either you are getting no pump shot or the secondaries are flopping open prematurely, or, if you have a choke it it closing somehow when you accelerate.
does the truck do the same with a different carb?
Old Apr 13, 2011 | 04:01 PM
  #74
AbandonedBronco
Heya 82, yeah, I've had two different carbs on it and it's the same deal.
Old Apr 13, 2011 | 04:31 PM
  #75
dustybumpers
time to pull the valve cover, and run it, and watch the valve train. Your going to spurt oil all over everything, but you'll see if the valves are opening and closing. I wonder if you bent a valve when you locked up the valve train? Was it this head or the other one that happened too?
