85 tbi to carb distributor shaft help
I have searched and searched reading many pages on this forum and have not found a direct answer on what dis. i should buy.. here is my problem the vac assist dis i need to install is about a half inch short.... check the picture... Is this not a worry or will the vac advanced dis oil pump not reach the rod??? Can anyone get me a exact year and make of a dist. that will work in my 85 302 motor that was converted to carb?? THANKS
DPDISXR4Ti
05-14-2012 08:11 PM
SubRanger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
10-04-2002 01:05 PM
1986, 302, 85, body, carb, carboretor, carbureted, conversion, distributor, f150, fe, ford, intake, shaft, tbi, throttle, windsor
