Hi all just wondering your thought on whether the factory tranny gauge is enough or should I install a second one to be safe. I do lots of towing and dont want to cook the trannsmission.
Factory is a glorified (but not great) idiot light.....built to look like a gauge but isn't. Same with the engine temp gauge. When my engine and tranny factory gauges say it's up to NORMAL, it isn't even close yet!
I don't personally have a factory gauge. But I know several who do, and read somewhere that the factory indicates "normal" until fluid gets well over 250.
Is fluid cooked or will tranny instantly fail at 250? No. But if in the middle of a hard pull, there are parts that are getting hotter than the average - and that is stressful. Failures occur instantaneously, but are usually the result of repeated cycles of high stress. Kind of like adding straw on a camel. I tend to keep my vehicles for several hundreds of K's. A key to getting there is to avoid high stress all along.
For me, I want to back off at 240 or 250 and definitely pull over and let 'er cool by 250 or 260 (depending on how safe it would be to do so). So a factory gauge would not be adequate for me. It is also nice to be able to watch the RATE of temp increase and adjust behavior to minimize risk.
With auxiliary gauges available for well under $100 and with test port so accessible, it is easy to do.
Is this true for the oil pressure gauge as well? Did any of the years get real gauges?
Definitely true for my '99. I have auxiliary for it as well. Factory oil pressure needle is fixed at middle of scale while the Autometer fluctuates between 20 and 70 psi.
That is actually less of a concern to me than trans temp. Oil pressure fluctuation like that is perfectly normal depending on condition of oil, temps, and RPM. Some folks would freak to see that much, so I understand Ford damping it so much.
This just really surprises me, I just traded in my 05 Chevy 1/2 ton which had all except the tranny temp gauge and they were true gauges. It also had an outside temp and direction in the mirror as standard equipment, but that is another topic.
I now have an 08 F350 V10, can I just change the gauges or do I need different sending units/wiring as well?
Even the oil pressure gauge was "undamped"? That is surprising, but good on them.
For the trans temp, the stock sending unit appears to be linear - the "damping" takes place in the ECM. But sending units HAVE to be calibrated to the gauge. The only aftermarket gauges that are known to work with stock sending unit are the electronic "PCM data display" style (Edge and others) that plug into stock electronics.
A gauge like an Autometer 2640 (what I have) require their own sending unit to read accurately.
On oil pressure, I think my stock sending unit is actually a switch rather than a linear sending unit.
Mine always stays in the middle. Once my trans temp gets to about 130 it does not move. On the 2011 with the productivity screen it has a digital readout with the temp reading. In the cold mornings it starts off at around 45, then goes up pretty fast once I get going.
