stumped??
Old Mar 24, 2011 | 12:45 AM
bmuhlbach's Avatar
bmuhlbach
I changed mine to a rear sump because of the drain plug location.
Old Mar 25, 2011 | 05:53 AM
corytcline's Avatar
corytcline
Did your motor have the dip stick in the block? Mine does so I'm thinkin I'm gonna go rear sump, does anybody know what to do about the whole I drilled in my timming cover for a front dip stick?
Old Mar 25, 2011 | 10:42 PM
bmuhlbach's Avatar
bmuhlbach
I put a 3/8 dowel in the hole in the front timing case cover to fill it.The oil pan I got was from a 86 F150 and the dip stick goes into the pan.You cann't use the front dip stick with the rear sump pan.
Old Mar 26, 2011 | 04:28 PM
corytcline's Avatar
corytcline
I already had a rear dip stick so good there, do I need to seal around the dowl pin with jb weld or something?
Old Mar 26, 2011 | 07:59 PM
bmuhlbach's Avatar
bmuhlbach
if its the factory hole then a 3/8 dowel pin will be a nice tap fit.
Old Mar 26, 2011 | 11:22 PM
corytcline's Avatar
corytcline
NO NO i DRILLED IT MYSELF AND FOR NO REASON
Old Mar 27, 2011 | 02:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
302 introduced in 1969 F100's (2WD only). The only available A/T was the C4 (11 trans pan bolt holes) thru 1977.
The C6 (17 trans pan bolt holes) was not available w/a 302 engine until 1978 and then only as an option.
If a 1969/79 F100; 1975/79 F150 came w/a 302 originally, the 4th digit of the VIN will be a G
D7TZ-6028-B replaced D0TZ-6028-A .. right engine support & D7TZ-6029-B replaced D0TZ-6029-A .. left engine support.
Fits: 1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD (support aka tower, stand, perch).
240/300 I-6 & FE perches: Same-o Same-o.
Old Mar 27, 2011 | 08:59 AM
corytcline's Avatar
corytcline
The truck came with a 302, the part guru let me know that in another post. My tranny must not be original the truck is 1970 f100 and you say that combo was not available till 78. I know I have a c6 just not sure from what, it is a c6 with the smaller input shaft I guesse some are for big blocks and ones like I have are for small blocks. I will find some numbers on it and post them today.
I know we are in a truck forums site but can anybody tell me if there is a site like this for old mustangs?
Old Apr 2, 2011 | 08:25 PM
corytcline's Avatar
corytcline
UPDATE: So I got a rear sump pan only one claiming to be stock replacement for 80'2 f150 at Jeggs was one made by Dorman Products? Pan looked the part but the wholes drilled for the bolts were slightly off I had to drill them out two sizes bigger before I could get the pan on correctly Don't by a dorman product pan I learned the hard way.
Old Apr 2, 2011 | 08:30 PM
bmuhlbach's Avatar
bmuhlbach
does it have the plug for the dip stick?
Old Apr 2, 2011 | 08:59 PM
corytcline's Avatar
corytcline
still have to get a plug for the whole I drilled in the timing cover. The dip stick I had worked perfect.
Mr. Ed
Nov 8, 2016 10:00 AM
motocrossross
Nov 4, 2014 08:39 AM
medino03
May 30, 2012 08:05 PM
friskyspatula
Jun 25, 2010 01:26 PM
JermKline
Jun 10, 2006 06:53 PM
