Bronco II Ford Bronco II
Weird noise
Old Mar 20, 2011 | 10:45 PM
89broncoll's Avatar
89broncoll
Weird noise
So I was pulling in my driveway tnite and my beonco started makin a noise.sounds like a bearing or joint but have no idea any suggestions where to start looking.
Old Mar 21, 2011 | 07:25 PM
mdr617's Avatar
mdr617
i had that also...it was my cv style driveshaft going up. but mine only made that noise under acceleration and going up hills and stuff like that
Old Mar 21, 2011 | 07:35 PM
89broncoll's Avatar
89broncoll
I can't tell what it is.I believe it's the brakes sticking.but I don't know?
Old Mar 22, 2011 | 02:15 AM
mdr617's Avatar
mdr617
if you think its the brakes sticking...take it for a drive and carefully feel the wheels/hubs...if they are hot or you feel a unusuall amount of heat, then they are sticking
Old Mar 22, 2011 | 07:50 AM
89broncoll's Avatar
89broncoll
Ok.just pulled into work.passenger side is warm.drivers side is cold.but theres also something clanking and when I ahift in and out of gear theres a clanking noise which makes me think u joints also
Old Mar 22, 2011 | 09:06 AM
89broncoll's Avatar
89broncoll
Old Mar 22, 2011 | 08:39 PM
89broncoll's Avatar
89broncoll
Took tire off play in bearings took everything apart and the bearings fell apart.replaced everything.still a noise but I believe it's the unlined massive play up and down and side to side
Old Mar 25, 2011 | 01:41 AM
fordtrucksj's Avatar
fordtrucksj
When was the last time you greased your joints (upper and lower)? Drag link? These will sometimes pop if they go dry.
Old Mar 25, 2011 | 09:04 PM
89broncoll's Avatar
89broncoll
Idk.just bought the rig.I plan on going through everything once it warms up.
droppedf100
Feb 22, 2010 06:48 PM
shurbs2004
May 18, 2007 04:14 PM
blwn88cpe
Oct 17, 2005 11:25 PM
designbc
Sep 3, 2003 09:59 PM
sixpack4401
Mar 20, 2002 05:08 PM
