Iratic throttle response
Old Mar 20, 2011 | 07:16 PM
jdevlin's Avatar
jdevlin
2007 Eddie Bauer Explorer
I have a intermittent issue with the throttle. when first starting the truck in the morning it is often very jumpy. When I push the peddle lightly the trucks jumps like I am rev it up and down. Sort of like when you see one of those newbies on TV trying to drive a stick for the first time.
Old Mar 20, 2011 | 07:57 PM
shorod's Avatar
shorod
You could start by checking the linearity of the Throttle Position Sensor (TPS). If you have a multimeter, connect it to the TPS on the resistance setting and slowly open the throttle. You should see a steady, linear increase or drop in resistance as the throttle is opened or closed. If you see a sudden jump or drop in the resistance, there is a non-linearity in the sensor and needs to be replaced. I don't guarantee it will fix the problem though, but could easily be a contributor.
I'm assuming you don't have a check engine light on or a misfire, and that the engine idles smoothly....
-Rod
Old Mar 20, 2011 | 08:10 PM
jdevlin's Avatar
jdevlin
Thanks. The engine runs smooth and after a minute of driving everything seems OK with the throttle.
f350rebel7788
Sep 22, 2011 09:53 AM
cartmanea
Jan 20, 2009 10:02 AM
Buzzsaw
3.0L V6
Feb 10, 2005 10:00 AM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
29
Jun 24, 2004 04:35 PM
levilevi2
Nov 6, 2002 04:32 PM
