1978 - 1996 Big Bronco
Speedometer problem!!!
Old Mar 20, 2011 | 01:43 PM
BigWheelin2's Avatar
BigWheelin2
I have a 91 Bronco w/ the E4OD tranny, my speedo stopped working and now it's making the tranny shift rough. Any clues on what would make the speedo stop workin and how to fix it?
Old Mar 20, 2011 | 02:33 PM
Encho's Avatar
Encho
The Southernmost Mod
The VSS or ABS has failed or lost contact. Don't run the truck until you solve this issue or you'll risk hurting the tranny. This sensor is located on the rear axle pumpkin's top (the only thing with a cable conected in the axle). Clean the terminals and see if the problem goes away, if it doesn't, replace the sensor.
Old Mar 20, 2011 | 05:27 PM
greystreak92's Avatar
greystreak92
Take the bolt holding the VSS into the top of the differential housing out. Pull the VSS out and wipe down with a lint-free rag. As Encho said, the problem persists after doing this, replace the VSS.
idahoFORD350
16
Jul 24, 2016 10:04 AM
Erik Jaeke
Oct 1, 2015 04:06 PM
dtbradio
Aug 12, 2015 04:29 PM
badger2196
Jan 7, 2015 06:11 PM
eagleridge5
Aug 10, 2013 05:40 AM
