1979 Ford Bronco Ignition
Old Mar 16, 2003 | 07:10 PM
antithrixdation's Avatar
antithrixdation
Question 1979 Ford Bronco Ignition
Hello Ford Fans, Recently Someone abandoned a 1979 Bronco in the woods on my property. The body is in sad shape but it was running and 4wd functional when left here. The local police want nothing to do with it and told me since its on my property I could do whatever I wanted with it. It is beyond road worthy but would make a good plow truck. While they left the truck they took the key!!! How do I hotwire this thing. I tried running a + lead to the coil and crossing the leads on that whatyamacallit next to the battery. that resulted in the engine cranking but no spark from the coil to distributor. someone suggested there are modules that also need current. also suggested the best way would be to hotwire the ignition switch itself. ANY HELP ON WHICH WIRES TO CROSS? It won't be long before the local vandals find it!!! help
Old Mar 16, 2003 | 07:40 PM
Franklin2's Avatar
Franklin2
Here's what the wiring should look like to the ignition module.
Old Mar 16, 2003 | 07:59 PM
antithrixdation
Thank you for your quick reply. schematics is what I was told to look for but alas electrical diagrams are not my strong suit. any other replys designed for a simpleton would also be appreciated. I will study this diagram and see if I can translate it. Thank you
Old Mar 16, 2003 | 08:57 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Anti, do what you did the first time, and in addition run a 12v jumper to the red wire going to the ignition module. This should give it some spark.
Old Mar 16, 2003 | 09:50 PM
Franklin2's Avatar
Franklin2
Is this going to be a long term solution? You really need that resistor shown in the diagram, and it's made into the harness from the original ignition switch.
Old Mar 17, 2003 | 05:50 PM
antithrixdation
Thank You both for your help it is greatly appreciated. I will give the lone rangers advice a try. As for long term usage, my first priority is to see how this truck runs and get it closer to my home. After determining its servicability I can replace the ignition switch. It may also be possible to jump the wires at the back of the switch, any thoughts on this? Once again Thanks
Old Mar 22, 2003 | 06:21 AM
antithrixdation
Thumbs down 1979 Ford Bronco Ignition
Sorry to say, still no spark. The rotor spins so the timing chain is still in one piece. Either the coil or ignition module is shot or there are other connections that are needed to be made. Any specific ideas on how to jump the ignition switch itself.
Old Mar 22, 2003 | 08:51 AM
thelonerangerxlt
Anti, when I first read your post, I wondered why the Bronco was abandoned. It must have been because it stopped running......
I think you're correct in that the trouble is in the coil or ignition module. My guess is it's the ignition module, because they have a history of failure (especially when they overheat).
A new module costs about $30; one from a parts yard even less. You can change both it and the coil out in 5 minutes. It might be worthwhile to beg, borrow, or steal a different module and coil, and try that.
You can still run a jumper from the battery + to the coil + (temporarily) to get it home.
Old Sep 24, 2010 | 09:43 PM
FourXFord2's Avatar
FourXFord2
If it was me I'd put the thing in neutral, then pull it closer to your house and work on it there.
Old Sep 25, 2010 | 08:03 AM
Franklin2's Avatar
Franklin2
This thread is close to 7 years old.
Osiyo59
18
Aug 2, 2024 05:47 AM
Daren1093251
Jan 23, 2017 12:30 PM
wrhatt
Mar 30, 2016 06:34 PM
coleboy11
1983 - 2012 Ranger & B-Series
Dec 3, 2011 09:42 AM
crewcab 350
Electrical Systems/Wiring
Apr 5, 2005 01:33 PM
