I recently installed a single speed electric fan, with a 30 amp thermostatic relay. I also have an msd box running off the batt. +
When the fan kicks in, the engine hesitates. Can someone pls. tell me how to resolve this issue.
Thanks.
Truck: 75 F350 with a hp 4.9
Alt.: G3 130 amp.
Fan: It is the larger of the two fans from a dual set up on a Ford Windstar.
Might be worth a call to tech support on that one. I know the box is sensitive on how you wire the power to it, but can't remember the details. Vagely remember a diode involved.
Below is a link to how I wired up my fan. Once you ckick on the link go to page 23 and 24. I believe page 24 is better since you fan will come one when it gets hot.
Your fan requires a lot of juice to run it. If your alternator or battery are weak then your fan will starve your engine of the eletricity that it needs to run it.
Some systems do use a diode but think of a diode as a one way street for electrons. A diode is often used when your engine does not want to shut off. This is not your case.
http://www.painlesswiring.com/Manuals/10101.pdf Your fan requires a lot of juice to run it. If your alternator or battery are weak then your fan will starve your engine of the eletricity that it needs to run it.
That was very helpful. I followed all diagrams/instructions at time of engine installation, but it never hurts to check again.
I'm sure you know this but I am amazed at how much current a good fan draws. I have my battery charger hooked up and I use it when I'm testing circuits in my car (so I don't drain my battery) and it is not strong enough to make my fan run. It will make everything else work but my fan is to big of a draw for it.
I notice you are running a powerful alternator. Mine is only 65 amps.
I use to have a boat and the belt would squeel like a pig when I trimed the motor. I guess the current draw was so much (my belt might have been loose too) when I raised the motor that it caused stress on the engine whereby making the belt squeel.
I read somewhere that a V belt can only turn IIRC up to a 70 amp alt w/o squeal. That is why manufactures went to a serpentine belt. P/windows, seats, two sp. fans, etc., so they had to supply more pwr. Some guys will put on a dual V belt pulley to counter this.
I'm old fashion. I like older trucks and I like V belts. Give me a carb and a oil sender unit that I can get to. Give me a truck where I can replace the engine myself. I look at an older truck and I see lower insurance, easier to maintain, easier to get to stuff, lots of stuff in the junk yards for them and you don't worry so much about a scratch.
Thanks.
Alt.: G3 130 amp.
What size wire do you have running from the alternator to the battery? You are not using the original harness correct?
I only notice hesitate for a few seconds when idling and the fan turns on.
I was very careful to follow the directions provided with the msd unit.
Another forum member says he encounted the same issue on another thread, and the problem was rectified by grounding the msd directly to battery -, and the fan to the body. As it is, I have the msd grounded to frame, and fan to body. A starting point for me would be to make that change.
You can try the other suggestion, but I believe you just have a alternator output problem at low rpm. I wonder if you set the idle up a little bit would the problem go away.
I was running a snowplow setup with an original 63amp alternator, and the electrical system would hardly pick the plow up with the defrost on, etc. I set the idle up just a little bit and it then would work fine.
