Radiator support modification ideas.
Old Mar 19, 2011 | 09:23 PM
blaze42069's Avatar
blaze42069
Well I have to pull my 7.3, My oil pan gasket has sprung a leak. I tried to cheat it once and it got worse. So I'm Ready to pull it, now what I want to do is cut the top of the radiator support out the width of the radiator opening then weld in some 1 1/2"x2" tubing and modify it to bolt back together like they made in the superduty rad supports. Then i can remove it for future purposes if needed. Anyone ever done this before? Or know of anyone who has? This would allow me to pull my motor without worrying its gonna fall on me! Any ideas would rock, thanx!
Old Mar 20, 2011 | 07:42 AM
Cuda_jim's Avatar
Cuda_jim
Since you are willing to cut and weld....why not leave the engine in and cut the cross member out to fix the oil pan. Much less work with no long term problems if your welding skills are OK.
Look here:
https://www.ford-trucks.com/forums/7...il-pan-qs.html
Old Mar 20, 2011 | 09:04 AM
Talyn's Avatar
Talyn
Yeah, if you can weld good, Cutting the cross member is the easy way.
Old Mar 20, 2011 | 06:05 PM
blaze42069's Avatar
blaze42069
I have read about cutting the cross member but I wasnt so keen on that Idea, I have already pullled everything off and all I got left to do is unbolt the motor mounts and out she comes. I will let you know how it goes, I'll just start cutting and hope all goes well
Old Mar 21, 2011 | 08:54 AM
Neal 97 250's Avatar
Neal 97 250
PICS.
We need PICS
Pescs334
1983 - 2012 Ranger & B-Series
Sep 30, 2023 09:54 PM
624WD
Oct 1, 2014 11:57 AM
56fordguy
Feb 5, 2014 03:24 PM
LeoJr
Jan 13, 2014 10:11 PM
ericfgs
1997 - 2003 F150
Jul 3, 2010 04:23 PM
