rattle somewhere in engine compartement
Old Mar 19, 2011 | 09:02 PM
cleaningbug94's Avatar
cleaningbug94
Okay so today we where at the dump i left the car running while i was unloading are 1998 ford expedition eddie bauer 4x4 with a 5.4 in it while i would hear a rattle like something was going to fall off about every 45 sec to a min can anyone give me a idea of what it might be has 171075 on it
Old Mar 20, 2011 | 02:38 PM
alloro's Avatar
alloro
Was the A/C on and perhaps the clutch was cycling on and off?
Old Mar 20, 2011 | 04:49 PM
cleaningbug94
No the ac was not on i know how that sounds and it is alot louder than that.
Old Mar 20, 2011 | 08:00 PM
briangelc's Avatar
briangelc
Belt tensioner
I just experienced the same sort of thing on my 5.4L. In my casenthe serpentine belt tensioner was worn out. if you can catch it doing it, you may see the pulley wheel wobble when the noise happens. It is on the front of the engine kinda passenger side - a pulley wheel on a swing arm.
When I removed the three bolts holding it, I saw the backside. The plastic seal and outer bearing race were gone. Only half of the ball bearings were still there. No lube. Amazing it worked at all. NAPA had the part, and a new belt since the old one had melted against the seized wheel. Ez fix
Old Mar 20, 2011 | 08:25 PM
cleaningbug94
Thanks its dark now will look at it tommarow i thought it maybe was my timing chain i was dreading that i hope that is not the problem.
Dr. Dirt
1997 - 2003 F150
Jun 29, 2014 09:40 PM
stephen.osborne1
1997 - 2003 F150
Jul 21, 2013 08:38 AM
damone
2004 - 2008 F150
28
Apr 30, 2012 10:17 AM
damone
Jan 27, 2006 09:52 AM
3fan
1997 - 2003 F150
Oct 18, 2003 09:19 PM
