Checking Valve Clearance
Decided to check the clearance in my valves today and am having some really confusing issues. ((Valve clearance as in the space between the rocker arms and the tip of the valves.))
For starters:
Everything in the valve train is new. Timing gears, cam, lifters, push rods, rocker arms, fulcrums, valve springs, valves, and head.
In my manual, it states the acceptable valve clearance is between 0.100 and 0.200. The preferred range is between 0.125 and 0.175.
So, I purchased myself a feeler gauge and bled my lifters down to empty. Then, went down the row and brought each cylinder to TDC and checked valve clearances.
About 6 of them were easily in the preferred range, usually around 0.150 or so. The rest of them were a lot lower, around 0.105 - 0.110. Still in the acceptable range, but just barely.
However, my frustration is coming with some of the cylinders having very varied readings. For example, cylinder 1, the first time I checked it, it read 0.125 on the exhaust and 0.165 on the intake. After going through them all, I went through them again. This time, it read 0.080 (E) and 0.095 (I)! Way out of tolerance.
After finishing them all again (many of them very close to what they read the first time), I decided to check cylinder one again. 0.140 (E) and 0.165 (I)
I'm confused. That's quite a discrepancy. All three times the piston was brought with great care to TDC (looking through the spark plug hole and barely wiggling the harmonic balancer with a breaker bar until the piston completely peaks).
What number do I go with? Why is it so varied? What am I doing wrong? Does it need a shorter push rod or not?
Thanks all.
Redid all the valves again on the compression stroke and here are the clearances I came up with.
1: 0.125
2: 0.162
3: 0.160
4: 0.169
5: 0.154
6: 0.162
7: 0.164
8: 0.150
9: 0.154
10: 0.164
11: 0.172
12: 0.130
Not sure why the numbers would be different on the different strokes. But if those are the valid numbers, looks like everything's right where it should be.
1: 0.125
2: 0.162
3: 0.160
4: 0.169
5: 0.154
6: 0.162
7: 0.164
8: 0.150
9: 0.154
10: 0.164
11: 0.172
12: 0.130
How did you bleed down the lifter to do this test??
Jim
Actually, I removed all the lifters (kept them in order), and then I had two extra lifters on the shelf that weren't pumped up. Went through cylinder by cylinder and moved the lifters from bore to bore, put the push rods in, installed the rocker arms, and then measured. Once done, I removed everything, moved the lifters to the next cylinder, installed, measured, etc., etc. Kinda time consuming, but it worked well, since I didn't really have any other means of bleeding my current lifters down.
Jim
