Which HPOP fitting do I have (STC or not)?
Old Mar 17, 2011 | 06:24 PM
Hunter,DDS's Avatar
Hunter,DDS
2005 excursion 6.0, motor is a 2004 build according the the valve cover. How do I know if I have the troublesome STC fitting or the older one? Thanks.
Old Mar 17, 2011 | 06:49 PM
starrs's Avatar
starrs
Most likely you have the problematic stc fitting. Just look at your hpop cover, if it's aluminum you need to replace it. I like the one piece from bulletproof, comes with tool to install. It's a snap and you get to reseal hpop at the same time.
Old Mar 17, 2011 | 10:45 PM
mackl1's Avatar
mackl1
Have a 2005 delivered Dec 2004 and had to replace the STC fitting if that tells you anything.
Old Mar 18, 2011 | 05:48 AM
npccpartsman's Avatar
npccpartsman
That's a really good question. IIRC the Excursion's had "older" motors put in the newer year models like the early production 04 trucks had 03 motors in them. It might be wise to take the last 8 of your VIN to your dealership and see if they can tell you if your motor requires the updated STC fitting OR if there was a particular production date split like the 04 trucks had at 9/29/03.
Old Mar 18, 2011 | 02:04 PM
Ian123's Avatar
Ian123
Sorry to threadjack but which years have the STC fitting? Is it anything after the early 04 engine?
Old Mar 18, 2011 | 03:36 PM
npccpartsman
05,6,7 motors have the STC fitting.
Old Mar 21, 2011 | 07:34 PM
smokersteve's Avatar
smokersteve
Is it updated in those years?
Old Mar 21, 2011 | 07:57 PM
npccpartsman
I don't believe that the updated STC fittings came out in the production engines until 07 and I'm not sure about them.
Old Mar 21, 2011 | 11:24 PM
bismic's Avatar
bismic
I have never seen where the updated fitting came out in ANY original production Ford 6.0L engines. I believe it did on the later Navistar engines, but Ford was slow to switch. Ford tried the bracket for a short while on some 07's IIRC.
Oleblue96
Jan 28, 2017 05:12 PM
Loftatsea
Nov 1, 2015 06:48 PM
Loftatsea
Oct 17, 2015 10:24 AM
jesuscowboy
Oct 4, 2015 08:48 PM
jwheatley20
Jun 19, 2010 11:45 PM
