TP Circuit above maximum voltage
Old Mar 16, 2011 | 08:35 PM
BigSouth's Avatar
BigSouth
Unhappy TP Circuit above maximum voltage
1987 Ford F-150 4x4 5.0L Truck won't start. Tries to turn over a couple of slow times, then nothing. Getting code 53: TP circuit above maximum voltage. What the heck does this mean? These codes don't explain enough for noobs like me! Is there anything I can check/replace/do to remedy this problem?
Sucks that this is my only means of transportation right now, and the piece of crap won't start.... Don't really want to throw hundreds of dollars of parts at it, if its not going to fix the problem. (been there, done that) Guess I could take it to a mechanic, but since I'm pretty strapped for cash, I've been trying to do things on my own. Can anyone help?
Old Mar 16, 2011 | 08:44 PM
subford's Avatar
subford
Check the wiring from the TPS back into the harness.
Check to see if you have ground on SIG RTN wire. (SIG RTN wire runs to the computer, through it and to the NEG post of the battery.
For more information on the TP Sensor go to this link:
Ford Fuel Injection » Throttle Position Sensor (TPS)
AGrayson84
2004 - 2008 F150
Nov 7, 2016 09:24 PM
Thedonk
47
Jun 22, 2016 11:52 AM
TexasMarkIII
13
Mar 14, 2013 09:36 PM
SideWinder4.9l
Jul 30, 2011 08:29 PM
greystreak92
1978 - 1996 Big Bronco
Mar 6, 2011 11:16 AM
