Headers and PS
Old Mar 16, 2011 | 08:11 PM
hotrodbob51's Avatar
hotrodbob51
Headers and PS
I need some advice are they to close? I am worried about the heat. I am going to run a cooler put not sure if that is enough.
Old Mar 16, 2011 | 10:40 PM
52 Merc's Avatar
52 Merc
That looks awful scary to me.
Old Mar 17, 2011 | 06:47 AM
hotrodbob51
It does to me too. May have to just rebuild my stock gear box. and sale that one.
Old Mar 17, 2011 | 08:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I think you would want at least an inch clearance and even then it will heat up the steering box some. That would be too close to suit me.
Old Mar 17, 2011 | 09:06 AM
hotrodbob51
If someone would like to buy that PS box and braket I made I may sale it. PM if you would like to.
Old Mar 17, 2011 | 09:51 AM
52 Merc's Avatar
52 Merc
Wouldn't it be easier/better just to find different headers/manifolds?
What engine are you runniing?
Old Mar 17, 2011 | 10:42 AM
GreatNorthWoods
I agree. Should be much easier to change the exhaust rather than the steering box!
Old Mar 17, 2011 | 10:52 AM
AXracer's Avatar
AXracer
What box is that?
Old Mar 17, 2011 | 11:15 AM
hotrodbob51
First when using the 351W there is no other header excepect fender well and they are costly. You can not us a rear type ford header. I have tryied. If someone knows let me know but i have ask in two other post.
It is a Toyota P/S G/B
Old Mar 17, 2011 | 11:24 AM
AXracer's Avatar
AXracer
I just got a message from anotherforum reader asking where he could get a Toy box. PM me with your email addy and I'll put you in touch. Don't know how much help the stock box is going to be, it's nearly the same size. Have you tried contacting Sanderson headers? Used to be they would modify their headers to fit if they didn't have for the application.
Old Mar 17, 2011 | 11:29 AM
hotrodbob51
The stock one does not come as far forward as this one does. Pm send.
Old Mar 17, 2011 | 01:38 PM
GreatNorthWoods
Have you considered using a stock type exhaust manifold? I was very limited with my 302 and Volare steering box in my 49 but I found that 64-66 Mustang cast iron exhaust manifolds work great. They should fit the 351W as well. I know they don't have the performance potential of headers but they clear most any steering box...
Old Mar 17, 2011 | 01:42 PM
hotrodbob51
I want to run headers. I may see about putting stanless shield around the G/B. Again with the 351W it is a little wider. A 302 would mostly work.
Old Mar 17, 2011 | 01:54 PM
GreatNorthWoods
Did you offset the engine? I offset my 302 two inches to the passenger side and even then I will have to use a shorty filter...
Old Mar 17, 2011 | 01:55 PM
BlueOvalRage's Avatar
BlueOvalRage
I'm going to guess that you've got the engine mounted with it centered in the chassis. Is there any reason that you can't cheat the engine over to the passenger side about an inch? Many, many factory installations are offset. It's a common thing.
Edit - Vern and I were thinking the same thing at the same time!
