Headers and PS
Old Mar 17, 2011 | 02:24 PM
AXracer's Avatar
AXracer
An 1/8" aluminum shield would work better as a heat shield. Don't attach it tightly to the box, leave air space and if you can shape it to scoop air from under the truck and in between all the better. Put a cooler in the return line where it can get air (Toyota put a cooler on this box if you happened to get it with the box).
Old Mar 17, 2011 | 08:42 PM
Huntfamily53's Avatar
Huntfamily53
Originally Posted by BlueOvalRage
I'm going to guess that you've got the engine mounted with it centered in the chassis. Is there any reason that you can't cheat the engine over to the passenger side about an inch? Many, many factory installations are offset. It's a common thing.
Edit - Vern and I were thinking the same thing at the same time!
add me to that...when I was going to put a 351c in mine I had planned for one inch offset for the same reason. It looks like you have the tubular mount like I had as well. If yours has not been welded up yet I would see if there is room to move it over. Just my 2 cents.
Old Mar 17, 2011 | 11:16 PM
AXracer's Avatar
AXracer
I agree! Even if you had to buy a new tubular mount to move it over it would still be cheaper than any alternative, and the Toy PS box works so well it would be a shame to go back to the stock manual box. You will need to move the tranny mount over the same amount, you want to keep the engine centerline parallel to the frame rails. As long as it remains parallel you can offset the engine as far to the passenger side as you have room. 2" offset is not uncommon, but 1" would give your box enough breathing room.
Old Mar 17, 2011 | 11:27 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
I have a 51 f1 with a 302 & aod my manifolds are off of a lincoln 80's-90's
look in my album i think that these might be your answer,i dont know how to post pictures here so look in my album
Old Mar 18, 2011 | 08:00 AM
GreatNorthWoods's Avatar
GreatNorthWoods
There are a number of OEM exhaust manifolds that would work but he wants headers...
Old Mar 18, 2011 | 09:22 AM
hotrodbob51's Avatar
hotrodbob51
Smile
I fixed the issue. I moved the eng. forward an 1" I cut the tube where my eng. mount bolt goes on the aft side and moved it forward. I forgot that I can move the rad. support to the six cylinder loction. I well send new pictures when I get it all done. Looks like I well have PS after all.
Old Mar 18, 2011 | 09:33 AM
AXracer's Avatar
AXracer
Good solution!
Old Mar 18, 2011 | 07:44 PM
carnut122's Avatar
carnut122
With it that close, I would think it would boil the ps fluid.
Old Mar 18, 2011 | 08:00 PM
AXracer's Avatar
AXracer
It would have as close as it was originally, but with an inch of clearance it should be fine. If it still tended to get hot then a simple inline cooler mounted in the airstream should take care of it.
Old Mar 19, 2011 | 09:22 PM
hotrodbob51
Old Mar 19, 2011 | 09:25 PM
hotrodbob51
I moved everthing forward with much more room. I well clean up the weld. The box is bolted all the way in and so is the eng and trans.
All so does any one know where I can get a new pittman arm nut and washer?
Beside's the dealer,
Old Mar 20, 2011 | 09:46 AM
AXracer's Avatar
AXracer
Try Mid Fifty, I got a new one with my conversion pitman arm from them. I had to cut the OEM to get it off.
Old Mar 20, 2011 | 09:48 AM
  #28
AXracer's Avatar
AXracer
If you get the headers HT powder coated it would help with the temp and add to their life as well as looking good.
hotrodbob51
Nov 11, 2012 07:29 PM
hotrodbob51
Sep 10, 2012 09:53 PM
hotrodbob51
Feb 26, 2012 05:46 PM
hotrodbob51
21
Jan 14, 2012 05:49 PM
hotrodbob51
Oct 3, 2010 02:40 PM
