if your going to listen to country i would not suggest a 12 inch sub, i would go with an 8 maybe a 10 here are pictures of the crude box i made for my 12 that i had in my 94 f150
and beware, if you put a high powered sub in your truck you will need sound deadening, or else it will sound like the truck is falling apart
and be careful in buying pre made truck boxes, i almost did and i built my own to the same specs as the one you would buy and it didnt fit, but good luck!
i plan on building another box for my f100 soon enough
