My air bag light is flashing on the dash of my 94 F150. The code is 32, three flashes followed by two flashes. Does any one know what this code means and how do I fix it? Thanks in advance.
Drivers airbag circuit resistance high. Is the cruise and horn also not working? If so this would indicate the clockspring is bad. Requires removal of air bag and steering wheel. Should only be done by qualified personal.
Thanks for the reply nitro94. The horn stopped working but recently it has been working. What am I looking at in labor hours to repair the clockspring?
>advance.
HELLO FOLKS,
I know its been some time since your issue but I have the same problem. I have the straight six with the 5 spped stick, the code is 32, did the Clock spring solve your issue ?
inhughman
If you end up changing yours, it's not difficult and doesn't require any special tools or procedures. I posted the procedure a week or so ago, copied straight from the Ford '96 service CD.
