My air bag light is flashing either 32 or 23 not sure which but after it flashes this a few times it stays on. Also my cruise quit working replaced the switch on the master cylinder. Went to auto zone and had them put a code reader on it and no codes came up although he said it would not show anything about the air bag. Money is tight right now and do not want to take to dealer. Would appreciate and advice. Thanks in advance.
Well I finally got around to changing out the clock-spring on my truck. The airbag light was flashing and the cruise control was not working and after installing the new part all problems solved. Thank you to all on FTE. I have learned a lot reading here and appreciate all the input I have received. Next project ARP studs and head gaskets and all upgrades involved with doing that project.
