EBPS Help
Old Mar 15, 2011 | 04:42 PM
99StrokeXLT's Avatar
99StrokeXLT
EBPS Help
I went to clean out the EBP sensor and tube today and found it totally packed full of crud. On top of that the tube that goes to the manifold had a whole in it. Has anyone had to replace their's, where did you get it?
Also, how do you know if you need to replace the sensor, the pics below are my sensor. I followed guzzle's directions and only cleaned it 1/4" deep and then blew on it to get as much as I could out. Does it still look ok?
Old Mar 15, 2011 | 04:58 PM
clintbonnie's Avatar
clintbonnie
You can order a new sensor and tube from one of our sponsor... www.partsguyed.com (just click on My Account and Contact Us and send a message requesting what you want, along with the VIN #).. Great prices for OEM Ford parts..
Old Mar 15, 2011 | 05:05 PM
roadrnnr's Avatar
roadrnnr
I recently replaced my EBPS tube, my old one was cracked too. My fuel mileage seems to be a bit better already. I ordered the tube from my local stealership. Thanks to Guzzle for a great write up!
Old Mar 15, 2011 | 05:12 PM
99StrokeXLT
Im trying to find it from a parts store for less Im betting ford is 60$ +, and these look about right but the website says they dont fit any ideas? EGR Line | AutoZone.com
Old Mar 15, 2011 | 05:31 PM
brownie83's Avatar
brownie83
you can get 24" of 5/16" SS brake line and use your old fittings and bend the tube to match old one. the sensor is salty...no matter where you get it
Old Mar 15, 2011 | 05:36 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
partsguyed as mentioned two post up.
Old Mar 15, 2011 | 05:52 PM
99StrokeXLT
I am sure Ed has everything...I'm looking to get this buttoned up so I am looking for places around here that will have it in stock. Also I would rather not replace the sensor if I dont have to. Is there a way to tell if it is still good, can anyone tell by the picture?
Old Mar 15, 2011 | 05:57 PM
tdpower's Avatar
tdpower
The only real way to know if it's good is to get it scanned for codes. When there is a problem with the sensor it won't set the CEL just a soft code.
Old Mar 15, 2011 | 05:59 PM
brownie83's Avatar
brownie83
mine looked better than that...and mine was bad
Old Mar 15, 2011 | 06:00 PM
99StrokeXLT
I know there is supposed to be a diaphragm in there but I could't see anything but junk in mine, and the whole definitely extends more than 1/4", would you be able to see anything in a new sensor?
Old Mar 15, 2011 | 06:06 PM
brownie83's Avatar
brownie83
i had code 0470 which i think is the sensor...and an 0478...the xx78 was for the broken tube(i think)..both were soft and never set SES...if you get the tube, install the old sensor, and scan for codes. mine came back without even running the engine. also make sure to clean out the hole in the bracket that the tube and the sensor mount too...mine was almost all clogged
Old Mar 15, 2011 | 06:18 PM
99StrokeXLT
also, Eds website says its down until the 1st, that seems like a long time to go without this system....
Old Mar 15, 2011 | 06:20 PM
99StrokeXLT
Chris, thanks this was very helpful. What kind of scanner do you need to do this? I definitely can't swing one of those right now, would one that Autozone has on hand work?
Old Mar 15, 2011 | 06:23 PM
Kyle_KleinSS's Avatar
Kyle_KleinSS
Guzzles site has them Replacement O-rings for Ford Diesel Engines
clintbonnie
It is up and running but slower than normal because of Ed's health problems... It might take a extra day to get a response..
