EBPS Help
Old Mar 15, 2011 | 06:25 PM
clintbonnie's Avatar
clintbonnie
Originally Posted by 99StrokeXLT
would one that Autozone has on hand work?
No..not compatible to our 7.3l
Old Mar 15, 2011 | 06:31 PM
Kyle_KleinSS's Avatar
Kyle_KleinSS
I would say buy a new sensor and make your own new tube with some brake line and a flaring tool and use the old fittings
Old Mar 15, 2011 | 06:46 PM
brownie83's Avatar
brownie83
i used a superchips scanner...i had it for an old truck i had...it seems to work fine. you can see if AZs scanner will work...its worth a shot...
Old Mar 15, 2011 | 06:50 PM
99StrokeXLT's Avatar
99StrokeXLT
So I have been looking around at different places online and the EBP tube is only available if I search under a 2001-2003 7.3l, anyone have any idea why? I am assuming that it would be the same as my 99.5, correct?
Old Mar 15, 2011 | 06:58 PM
Randomsht's Avatar
Randomsht
Got my EBP tube here RockAuto Parts Catalog They call it an EGR line. Fit pretty good for $22.
Old Mar 15, 2011 | 07:15 PM
99StrokeXLT
This is where I'm looking now, but I could only find the part under the 2001 and newer model years. Did you find yours under the 99 category?
Old Mar 15, 2011 | 07:26 PM
99StrokeXLT
If I can get one for 22 buck online, it would be cheaper than buying the tube, fittings, and a flaring tool...but I wish I knew someone with a shop and some extra parts, it really would be so quick and easy
Old Mar 15, 2011 | 07:46 PM
brownie83's Avatar
brownie83
where are you at...i have all the tools you would need for that job and some others...no parts though...for that
Old Mar 15, 2011 | 07:48 PM
damicofuel's Avatar
damicofuel
Cap it off at manifold and delete it!
Old Mar 15, 2011 | 07:50 PM
99StrokeXLT
Boston, MA. I think the cost of that drive might be a little more than the new tube. I appreciate it though! gotta love the brothahood
Old Mar 15, 2011 | 07:54 PM
99StrokeXLT
I'm gonna go a head and assume that's a joke, hahahah
Old Mar 15, 2011 | 07:55 PM
brownie83's Avatar
brownie83
yeah...im in NEPA...but thats pretty far for a tube...we are having a NEST spring fling here...its the last weekend in april/first day of may...you are more than welcome
Old Mar 15, 2011 | 07:57 PM
  #28
brownie83's Avatar
brownie83
people do it...even i did, but i was told 1st hand by a tuner...they need that sensor to fueling parameters...also i have read that jody from dp also says his tunes need the input. i just replaced my tube and sensor...i read a lot and ended up just sucking it up and buying the tube and sensor. if i do it again...ill make the tube. good luck
Old Mar 15, 2011 | 07:59 PM
  #29
Kyle_KleinSS
Reuse the fittings, and you can rent flaring tools from auto zone or oriellys and you get all of your money back when you return it. And a bender for the brake line too. But 22 bucks is probably a good deal save alot of time, I was just recommending that if you didnt have time to wait
Old Mar 15, 2011 | 08:04 PM
  #30
99StrokeXLT
Yea, this was the first I have heard of just plugging it so I though it was a joke based on all the info I have read about how important it is to have functioning properly and the improvement in mpg's people are reporting. Didn't mean to offend.
Chris, I found the tube on Rockauto for $22 but it is only listed as compatible for a 2001-2003, the only thing keeping me from buying it is that it doesn't show up under my '99 model year, opinions? The motorcraft sensor from Rockauto is only $76 too, so depending on what people think I might just go this route.
Why would the part not be listed on the '99 and '00s?
