I know I saw these posted but haven't been able to locate. Does anyone have them or know where to view? All I've found is Ecoboost has higher 6th ratio than the others but I'd like to see the rest.
I'd seen the .61 ratio before & finally found some info after searching, here's the quote, (it's .69 for all the others):
Transmission
The F-150 EcoBoost has six forward gears and one reverse gear. The high ratios of the first gear and reverse gear give this little truck a lot of pulling power, and the low ratios of the fifth and sixth gears make for great fuel economy on the highway at high speeds. The first gear ratio is 4.17 to 1, the second gear ratio is 2.34 to 1, the third gear ratio is 1.52 to 1, the fourth gear ratio is 1.14 to 1, the fifth gear ratio is 0.86 to 1, the sixth gear ratio is 0.61 to 1 and the reverse gear ratio is 3.40 to 1. The 6R30 automatic transmission has a toggle switch that lets you change to manual gear changing.
From the service manual. Don't know who's right on this, but I tend to believe the Ford manual. This was taken right from the service publications on motorcraft.com
Gear Ratio
1st 4.17 to 1
2nd 2.34 to 1
3rd 1.52 to 1
4th 1.14 to 1
5th 0.87 to 1
6th 0.69 to 1
Reverse 3.40 to 1
Stall Speed
Engine Min Max
3.7L 2300 2580
5.0L 2400 2700
3.5L GTDI 2300 2580
6.2L 2,000 2,250
