2011 transmission ratios
I know I saw these posted but haven't been able to locate. Does anyone have them or know where to view? All I've found is Ecoboost has higher 6th ratio than the others but I'd like to see the rest.
My understanding is the the transmission is the 'same' as the 09-10, with the exception of the manual shift.
Here are the ratios for the 09-10: 1st: 4.17:1 2nd: 2.34:1 3rd: 1.52:1 4th: 1.14:1 5th: .86:1 6th: .69:1 |
Originally Posted by shotgunz
(Post 10095237)
Thanks, guys, that's what I needed.
According to the 2011 Factory service manual, all 11's have the same gears.
I'd seen the .61 ratio before & finally found some info after searching, here's the quote, (it's .69 for all the others):
Transmission
Read more: Ford F-150 V6 EcoBoost Specifications | eHow.com Ford F-150 V6 EcoBoost Specifications | eHow.com Also this: http://trucktrend.automotive.com/145...ecs/index.html Shows the Ecoboost with .61 |
From the service manual. Don't know who's right on this, but I tend to believe the Ford manual. This was taken right from the service publications on motorcraft.com
Gear Ratio 1st 4.17 to 1 2nd 2.34 to 1 3rd 1.52 to 1 4th 1.14 to 1 5th 0.87 to 1 6th 0.69 to 1 Reverse 3.40 to 1 Stall Speed Engine Min Max 3.7L 2300 2580 5.0L 2400 2700 3.5L GTDI 2300 2580 6.2L 2,000 2,250 |
