1978 - 1996 Big Bronco
wheel bearing adjustment
Old Mar 15, 2003 | 10:49 PM
budman's Avatar
budman
Hi all,
I've got a '90 Eddie B. with auto hubs - had to replace both brake rotors.
My question is how do you adjust the wheel bearing nuts? There is an inner and outer one. I believe the manual states that you torque the inner nut to 50 lbs and back off a 1/4 turn - but what about the outer nut?
TIA for any info.
Budman
Old Mar 15, 2003 | 11:32 PM
SmaulzEB's Avatar
SmaulzEB
I believe that one's torqued to 150ft/lbs. Somebody correct me if I'm wrong...
Old Mar 15, 2003 | 11:46 PM
steve83's Avatar
steve83
For "later models" with only 1 nut, the Haynes manual says to set the adjusting nut at 70 lb-ft while rotating the wheel, then back off 90° & retighten to 15-20 lb-ft.
If you have an inner & an outer, tighten the inner to 50 lb-ft while rotating, back off 45°, put in the lock washer, & tighten the outer to 150 lb-ft.
Old Mar 17, 2003 | 11:23 AM
budman's Avatar
budman
Sounds good - thanks for the help
Budman
jonnyrodder
Mar 22, 2017 05:00 PM
bbyrnes1
Aug 10, 2016 02:54 PM
Chefsteele
46
Dec 31, 2013 07:43 PM
Notpilbrisk
Jun 16, 2013 07:15 PM
DanZ
Dec 1, 2003 08:48 AM
