Another head stud job
Old Apr 12, 2011 | 09:04 PM
  #46
429poweredf350's Avatar
429poweredf350
Originally Posted by Young Gun
Nice work!
What oil cooler did you go with?
The updated factory one.
Old May 8, 2011 | 08:20 PM
  #47
SUPERDUTY_WILL's Avatar
SUPERDUTY_WILL
Jerry those are two bad *** trucks, two of my favorite Ford body styles. I can tell by looking under the hood you keep you stuff clean and in excellent shape. You did all that without removing the front radiator support structure ?. I think I have a couple of bad injectors and I was going to try and do them myself in my driveway. I used to wrench for a living but not on diesels. Would you recommend me giving this a go ? Thanks and great job on your project
Old May 8, 2011 | 08:58 PM
  #48
mah77's Avatar
mah77
Nice job! I just recently blew my headgaskets from an overboosting turbo. Fortunately an aftermarket warranty covered mine. Upgraded the necessary components, and had them install ARPS. Ill bet your rig runs like a raped ape!
Old May 9, 2011 | 07:55 AM
  #49
429poweredf350
If you're handy with a wrench, I'd definitely do it yourself. Injector replacement is not that bad at all. Good luck.
Old May 9, 2011 | 08:02 AM
  #50
429poweredf350
Update
Took her on a 1200 mile trip to VA over the weekend. It ran like a clock, never missed a beat.
Old May 9, 2011 | 09:11 AM
  #51
2006powerstroke90's Avatar
2006powerstroke90
Gald to hear it
Old Jul 20, 2011 | 11:05 PM
  #52
AndeyHall's Avatar
AndeyHall
I'm guessing it would be a good time to give the engine a good cleaning while you've got everything apart? My engine is NASTY but it was that way when I bought it. I've been wanting to clean it up, so now that I have a reason to break it down I guess I will.
Old Jul 20, 2011 | 11:06 PM
  #53
AndeyHall's Avatar
AndeyHall
What are the best engine cleaning products?
Old Jul 21, 2011 | 07:58 AM
  #54
429poweredf350
Gunk has always worked well for me
Old Jul 21, 2011 | 10:22 AM
  #55
AndeyHall's Avatar
AndeyHall
Located at? Do you know of a product that's pretty much the same? Because if you're from up north or out west we probably have different stores and different products.
Old Jul 21, 2011 | 11:21 AM
  #56
429poweredf350
Any kind of engine degreaser will work.
Old Jul 21, 2011 | 11:24 AM
  #57
AndeyHall's Avatar
AndeyHall
Sounds good. So did you do anything special to get the back problematic headbolts out. Some have mentioned removing the engine mount bolts from the frame and lowering the engine a little. Did you do anything like that?
Old Jul 21, 2011 | 03:40 PM
  #58
429poweredf350
See post 36. Didn't really have any problems once the inner fenders were out. Never messed with the motor mount bolts. When reinstalling, The rear 3 studs must be in the passenger side head when its lowered into place as well as the rear lower dvr side head.
Old Jul 21, 2011 | 03:50 PM
  #59
AndeyHall's Avatar
AndeyHall
Yeah I had heard most people were putting 3 in on the pass side and 1 in on the drivers side, but there was one guy who said even then he couldn't get his factory bolts to come out or the studs to go in without dropping the back of the motor a few inches.
johnsonjf
Mar 16, 2017 08:46 AM
akblackfoot
Apr 25, 2016 12:23 PM
bigdieseldav
Mar 12, 2014 10:50 PM
vlietracer64
Nov 3, 2010 10:35 PM
Piolet
Jun 7, 2010 04:14 PM
