Another head stud job
Old Mar 21, 2011 | 11:57 AM
2006powerstroke90's Avatar
2006powerstroke90
It always seems like it never goes like it should...
but it seems like with everything you are doing you should be good for a while.
cant wait to see pics
Old Mar 23, 2011 | 10:05 PM
rdunagan's Avatar
rdunagan
just checkin in to see how things are coming?
Old Mar 24, 2011 | 10:58 AM
429poweredf350's Avatar
429poweredf350
Won't get back to it till Friday evening. Got some snow here today and had stomach virus for last 2 days......not pretty. It's supposed to warm up into the upper 40's for the weekend!! I'm hoping to have it all buttoned up by the end of the weekend if all goes well.
Old Mar 26, 2011 | 01:17 PM
429poweredf350
Cheezit, you out there?
I got my heads set back on and torqued. Tried to spin the engine over by hand as you suggested and goes all the way around then bang....sounds like it hits something and stops. Sounds like drivers side bank. #5 perhaps??? I read your post in another thread about #5. What is this stopage? Is it the lifter itself? What is the remedy and where should I go from here?
Thanks,
Old Mar 26, 2011 | 01:25 PM
TAT2DUP81's Avatar
TAT2DUP81
How much did you spend for parts you're replacing?
Old Mar 26, 2011 | 01:48 PM
429poweredf350
About $2K........
Old Mar 26, 2011 | 01:53 PM
429poweredf350
I have another concern. I set the head gaskets and heads on Sunday last week. It got dark, weather got bad, I got sick so I couldn't torque them until this weekend. My concern is there was some oil that must have leaked down from the head and some coolant that ran down the side of the block. This came from between the head and block surface. Will this be an issue? I finished torqueing the heads this morning but didn't see it until I was finished. Thoughts??
Old Mar 30, 2011 | 02:31 PM
429poweredf350
Update
Down to just the intake and turbo left to install. The intake was a mess. A lot of oil inside it. Finally got it all clean. I took a break from the engine and installed my new Redhead steering box the other day. I haven't had a chance to drive it yet and already feel a noticeable difference in the wheel. I'm going to try and attach some pictures of my progress. Thanks for the help.
As low as I could get it
oil in the turbo intake
Stripped
HPOP
Old style STC fitting
New STC fitting installed
HPOP Valley
Oil cooler....Nasty
Broken HPOP screen
Rebuilt Oil Cooler
New gaskets
I can't stress enough the importance of staying organized.
Left Bank
Right Bank
New Stuff
Red Head
Old Mar 30, 2011 | 03:36 PM
rdunagan's Avatar
rdunagan
awesome pictures!!!!!! well i just realized the difference in the old style stc fitting and the new one. looks like mine already had the new one but o well i replaced it anyways. glad its all going good!!
Old Mar 30, 2011 | 08:06 PM
counciller's Avatar
counciller
Excellant pictorial - enjoyed it
Old Mar 30, 2011 | 08:45 PM
2006powerstroke90
Nice pictures! Doing it in your driveway too nice.
How hard was it to do the stc fitting, I think mine is starting to leak.
As for thump it might be a bent push rod? Happened to me, didn't catch it until the truck was back together 100%
If you still have valve covers off, I'd say pull the oil rails and check the rocker arms out and push rods, when mine bent it was in cylinder 5 and it was easily noticeable.
Old Mar 31, 2011 | 08:36 AM
429poweredf350
STC fitting wasn't bad at all. Kit includes everything you need to do the job.
Old Mar 31, 2011 | 09:01 AM
  #28
bismic's Avatar
bismic
Nice thread - thanks
Old Apr 2, 2011 | 09:23 AM
  #29
2006powerstroke90
Are we going to hear good news this weekend?
Old Apr 2, 2011 | 09:58 PM
  #30
429poweredf350
Just about ready to go. Need to put the fluids back in and finish the CCV reroute. Should fire around noon.
