map sensor problem!
Old Mar 15, 2011 | 09:19 AM
bismic's Avatar
bismic
Originally Posted by embry1123
What about a possible plugged (partially) cat?
If it is, you still have underlying problems with combustion somewhere.
Old Mar 15, 2011 | 09:24 AM
embry1123's Avatar
embry1123
agreed, this morning I got a p0500 code (vss) however if that was actually bad owuld it not also effect the speedo and the ABS? Is there a possibility that the FICM can also be bad even though I have a consistant 48.5 volts showing with Auto Enginuity?
Old Mar 15, 2011 | 09:28 AM
embry1123's Avatar
embry1123
I'm going at lunch today to get the batteries load tested, but don't really understand how a week battery could give me so much grief.
Old Mar 15, 2011 | 03:36 PM
npccpartsman's Avatar
npccpartsman
It could be the transmission shuddering. Checked the fluid?? Also, the VSS could be causing intermittent problems, but usually if it's bad the trans. won't shift and act all kinds of crazy.
Old Mar 15, 2011 | 06:15 PM
embry1123's Avatar
embry1123
VSS isn't setting a code anylonger. The speedo never quit working and the trans has shifted properly all along... until going home from work today. Of course the motor was loading up so bad it wouldn't accelerate so no surprise the trans wouldn't shift. By loading up I mean it was acting like a 2 stroke dirt bike with a fowled plug, LOTS of blue smoke and no power. I eased off the throttle and it cleared up, tranny shifted (harsh) and it began to move better. As the truck warmed up completely it seemed to run a bit better. Highway speed I can accelerate without problem. At cruise around 60 or so the shutter starts but if I let off a little or accelerate a little it goes away. Tranny fluid looks great and is at the proper level, oil is at the proper level as well is the coolant and the degas bottle hasn't burped. I just got the new software and firmware update today for the A.E., so I'll take it for a drive and record some things. Which would be the most important to monitor at this point?
Old Mar 15, 2011 | 08:35 PM
Euroglenn's Avatar
Euroglenn
I had the same symptoms a few months back, I checked the FICM and it was fine, so I took it to the dealer(I have an 06 so it was still under warranty). It turned out to be a bad injector.
On another note, do you have to have the Ford add-on software for AE to make it work? I was thinking about getting AE, but I saw on the website that PSDs need the add-on.
Old Mar 15, 2011 | 08:48 PM
embry1123's Avatar
embry1123
The add on is from AE. You have to purchase the Ford Enhancement. I think you can get it from RiffRaff Diesel for around 350.00 including the enhancement
Old Mar 16, 2011 | 05:56 AM
npccpartsman
Still sounds like an injector to me. I have the same problem until my EOT gets to 160*.
Old Aug 29, 2020 | 02:07 PM
truck_liddelle's Avatar
truck_liddelle
I actually get a surging boost when accelerating hard. Like something is sticking. It will boost then flat then boost then flat then boost. All of this happens very rapidly. The shuttering when it drops into overdrive is the worst of the problems, I just have to think they are connected. It also sometimes takes more foot feed than normal to get it to kick out of overdrive.
What was the end result and the problem? I’m experiencing the same thing, boost will drop off and I loose power, white smoke puffing out the exhaust. Any help would be appreciated if you figure it out.
Old Aug 29, 2020 | 02:27 PM
Hartwig's Avatar
Hartwig
How many mls do have on the turbo? Has it ever been cleaned? Did you check for DTCs?
Old Aug 29, 2020 | 02:53 PM
bismic's Avatar
bismic
It is likely that you have an injector issue.
You need to download ForScan Lite to a smartphone, buy the appropriate OBDII plug, and check for codes.
Old Aug 29, 2020 | 04:34 PM
truck_liddelle
I have torquepro, I checked for codes and a MAP/Baro code came up. Injectors were changed 30k miles ago so hopefully that’s not the issue. Any way to check map sensor or if I get the code do I have to replace it?
Not sure of miles on the turbo VGT seems to be normal as far as I can tell.
Old Aug 29, 2020 | 07:59 PM
  #28
bismic's Avatar
bismic
ForScan is a better code reader than Torque Pro, but Torque Pro isn't bad.
Check to see what MAP, Baro, and EBP all read at KOEO and post.
Old Aug 30, 2020 | 10:03 AM
  #29
truck_liddelle
I’ll download ForScan, thanks for that. Here’s my readings: MAP: 14.8 Baro: 14.5 EBP: 16.3
edit: all readings in PSI
Old Aug 30, 2020 | 11:26 AM
  #30
npccpartsman
That's virtually identical to what my 04 has always read KOEO. Sounds like a bad injector to me too. Any codes? EGR present or deleted?
