Auto vs Manual starters
Old Mar 14, 2011 | 07:31 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Are there any differences between the starters on an automatic vs a manual truck?
I just had the starter for my auto transmission rebuilt a few months ago, so I'm hoping I won't have to get another, I'm putting a manual transmission into the truck.
Sam
Old Mar 14, 2011 | 07:46 PM
jim collins's Avatar
jim collins
I have a couple of each in the shop and the auto is a little longer,about 3/8 of an inch. I have used manual ones on the 302 with the c/4.,sometimes they won't ingage good. I only did it a few times and thought i might damage the newflex plate ,so i bought the right on. No more missing the ingagment. You could just try it ,if it misses ingaging the flexplate ,then you know what to do. JIM
Old Mar 14, 2011 | 07:59 PM
jim collins
I just reread your post and see you are going the other way. The starter may be to long and jam in to the flywheel. You can get shims to move it out at the NAPA parts stores and a few others. It's just a ring with bolt holes in it about 1/8 of an inch thick ,so it might take a couple. I have used them,don't really like them but i had the same problem once and used them until i needed a new starter ,then i got the right one. Ford made them at one time for a few years but not anymore i heard .Part number D6TZ-11N004 , H.M.C. makes them now unless they have discontinued too.
Old Mar 14, 2011 | 08:08 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
No difference for FE engines...
Josh
Old Mar 14, 2011 | 08:57 PM
jim collins
Sam, i think the problem is only with the small block,289.302 and maybe 351w. I'v never had the problem with 460 ,351m or 400. Never owned any others. Here's what it looks like ,you may not need it .
Old Mar 14, 2011 | 09:46 PM
Rusty_Old_F250
Sorry, I should have mentioned what motor, it is an FE. I think you folks just saved me $50!
On a similar subject, how hard is it to replace the ring gear on a flywheel? Or should I just have that done at the machine shop? It will be going to there anyway (needs to be turned) but if I can save a dollar, I'm all ears!
Sam
Old Mar 14, 2011 | 10:44 PM
Bullitt390's Avatar
Bullitt390
They may swap the gear for under $10, otherwise if you have a torch you can cut the old one off and heat the new one on. Doesn't take very long.
YouTube - Ring Gear
Josh
Old Mar 14, 2011 | 11:39 PM
Rusty_Old_F250
That doesn't look hard at all, I think I'll go ahead and do it myself.
Sam
Old Mar 15, 2011 | 02:16 AM
78 PEB's Avatar
78 PEB
Throw the new ring gear in the oven for half an hour to 45 min. It will drop right on. If you want to be double sure it will drop on, throw the flywheel in the freezer at the same time. Not hard to do.................
Old Mar 15, 2011 | 07:10 AM
jim collins
So that really works huh ? Somebody told me that once,but he was such a story teller ,i never paid much attention to him. I'l keep that on my ,believe it list,L.O.L.
Old Mar 15, 2011 | 03:35 PM
Rusty_Old_F250
I've heard of the oven trick, I'm sure mom would appreciate me throwing the ring gear in the oven and that dirty flywheel in the freezer! Maybe if I clean them first...
Nah, I've got a buddy with a torch, I better give him a call.
Sam
tndallas
Nov 15, 2020 02:59 PM
BTFordGuy302
Jun 24, 2017 07:16 AM
jamesh23
26
Jul 19, 2016 10:47 AM
rkmason
Mar 1, 2016 09:44 PM
Twotall
26
Sep 24, 2014 06:58 PM
