No Reverse Lights ????
Old Mar 23, 2016 | 09:57 AM
E55 Bulldog's Avatar
E55 Bulldog
Ok, new day, new issue....
Neither of my reverse lights are lighting up when I but the truck in reverse.
I checked the fuses and they are all fine, bulbs look fine, but Im not getting power to them....
I have an auto tranny, is there a switch or harness I need to check? And how do I do that?
Old Mar 23, 2016 | 10:29 AM
fordpride's Avatar
fordpride
Have someone watch the lights while you slowly move the shift from P to N to see if the light up. The switch(TRS) could be out of adjustment or bad, the shift leaver bolts could be loose or bad wires
Old Mar 23, 2016 | 10:34 AM
E55 Bulldog
Ok, so I just jumped #6 and #7 on the harness and the lights worked. Did a video of me switching through gears and the lights will flicker. The MLPS looks new from when the tranny was rebuilt... I also noticed I cannot get into 1st gear.
So... I guess it is an alignment issue? How do I go about aligning it are there marks?
Old Mar 23, 2016 | 10:42 AM
E55 Bulldog
Also, would this be causing my shifting issues or my P0500 code?
Should I just replace it with a new one just to be safe?
Old Mar 23, 2016 | 11:09 AM
E55 Bulldog
Ok, I got it re-aligned and the lights work now
I did over tighten the mounting bolds on the MLPS / NSS and cracked the plastic corner... is that going to cause issues down the road?
Old Mar 23, 2016 | 12:23 PM
fordpride's Avatar
fordpride
Check these bolts under the dash
Old Mar 24, 2016 | 10:18 AM
BadDogKuzz's Avatar
BadDogKuzz
Great photo Mike ! Also great advice I agree with even you had just said. When I had an issue like this years ago it was all of the above. Since you posted this photo of the torx bolts I am going to go and recheck them today hopefully they haven't loosen up any. I don't think so but it can't hurt to check also if I recall correctly I used blue loctite on them when I did it about 5 yrs ago.
Old Mar 24, 2016 | 10:21 AM
E55 Bulldog
Yeah, Im going to check mine as well. Everything is loose on this truck. Im guessing form years of vibration?
leetudor
Jan 7, 2025 05:37 PM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
troupstree
Jul 7, 2014 11:17 AM
sjguy105
Mar 26, 2012 08:48 PM
Wizardvette
1997 - 2003 F150
Jan 10, 2005 11:21 PM
