NEED HELP
Old Mar 12, 2011 | 06:52 AM
scollet's Avatar
scollet
NEED HELP
does anyone know if a 6 stud mounting flywheel/flex plate will work on a 89 idi non turbo with the e4od ..it had the 4 stud mounting flywheel/flex plat and got a triple lock and its a 6 stud..will it mess up balancing? are what?
Old Mar 12, 2011 | 08:03 AM
84-6.9L's Avatar
84-6.9L
If a flew plate from a 7.3 psd is a 6stud you might have luck just switching flexplates because they are balanced by the flywheel and the balancer up front, the flexplate is more ofa adapter that fits in the flywheel. However ive never seen what kinda setup a psd has.
Old Mar 12, 2011 | 08:35 AM
farmert's Avatar
farmert
First let me sya that I'm not an auto tranny guy, but from what I understand the 6 bolt converter is for a Stroke, and the 6 bolt flex for the Stroke will not work on the IDI. David or someone with more Knowledge of these E4od will be along to help you out.
Old Mar 12, 2011 | 11:48 AM
scollet's Avatar
scollet
see but this has that geared cast iron flywheel and then that thin flex plate the torque converter bolts to and i know i could drill the flex plate out to get it to fit but then the wholes in the geared flywheel wouldnt line up to tightin the TC and u cant bolt the TC to the flex plate then the flex plate and the flywheel to the crank shaft cus thats in fron of the TC
stormy750
3.8 & 4.2L V6
May 28, 2013 11:06 PM
Twistedwrench
WTB - Parts & other
Nov 6, 2012 06:36 AM
scollet
Mar 12, 2011 06:34 PM
scollet
Mar 12, 2011 04:42 AM
daddy57
Jan 28, 2008 08:19 AM
