od light flashing-- help please
Old Mar 12, 2011 | 06:03 AM
fixitman1310's Avatar
fixitman1310
hey guys need a little help or advice
i bought a 95 f350 powerstroke at auction. batteries were completely
dead and had to jump it off when i picked it up. the odometer,speedometer
back up lights are not working. od light flashing on shifter. also the abs
yellow on the dash is on. no check engine light though. i havent checked
the fuses yet. i used a scanner and only got a memory code. i reset
the codes and the od light is not flashing not flashing now, but i still
have no speedometer or odometer. abs light still on. any help or ideas
would be greatly appreciated. 95 f350 270000 miles e4od
thanx guys steve north carolina
Old Mar 12, 2011 | 08:29 AM
Oslo's Avatar
Oslo
I had this problem 2 weeks ago It was one of the big maxi fuses under the hood. It controlled the speed o the odometer the automatic trans shifting and the ABS light was on. I can pop my hood & tell you the # in a bit.
Old Mar 12, 2011 | 09:54 AM
fixitman1310
thanx alot for the help i really need the help
steve
Old Mar 12, 2011 | 10:45 AM
Oslo's Avatar
Oslo
Maxi fuse # 10 it is also linked to your instrument panel fuses 15, 18 & your starter coil relay good luck
Old Mar 12, 2011 | 04:13 PM
fixitman1310
i checked all the fuses and test good. what else should i check. could the speed sensor
be bad.
Old Mar 12, 2011 | 04:14 PM
fixitman1310
what are some of the other causes of this
thanks
Old Mar 12, 2011 | 04:19 PM
redman84's Avatar
redman84
The speed sensor can cause the flashing OD light. Does it shift funny? Pull the sensor out of the top of the rear end and check it out. May need to be cleaned up and put back or replaced all together.
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You should check what code has been stored in memory. Otherwise you're going to waste a lot of time and money.
Old Mar 12, 2011 | 04:25 PM
fixitman1310
hey mark i have the auto enginuity scanner and got no codes. what scanner
should i use to get the code
thanks alot
steve
Old Mar 12, 2011 | 07:06 PM
Oslo's Avatar
Oslo
I don't mean to keep on this fuse thing but mine tested good installed with a meter. You need to pull every one and viaually check they could be hanging on by a thread & reading continuity.
Old Mar 12, 2011 | 08:06 PM
fixitman1310
oh ok i will recheck the fuses thanx alot
